The camper thread! Pulling, using, equipment, maintenance!
Old Oct 26, 2015 | 08:22 PM
  #1201
Snowseeker's Avatar
Snowseeker
Our TT is put up for the winter. I just have to dump some antifreeze down the drains and she'll be set.
Old Oct 26, 2015 | 08:37 PM
  #1202
copsey's Avatar
copsey
Snow, are you just using air in the lines to blow them out? This is my second time winterizing and that is my plan plus antifreeze in the traps and some in the tanks.
Old Oct 26, 2015 | 11:15 PM
  #1203
Pwrgeek's Avatar
Pwrgeek
Originally Posted by Restlesswildman
When plugged in the inverter provides the 12V voltage and charges the batteries. Inverter output is 13.6-13.9 and is within spec.
But I will put the multi meter on the batteries and check.
Sounds like you've got a bad battery. With the system plugged into 110 and the converter on you should measure 13.5 - 13.9 V with all the loads turned off. Even with everything on you shouldn't be able to pull this down to 12. With everything off you should measure at least 12.5 on the battery by itself. If you want to know for sure plug the trailer in over night and then disconnect the battery. If you measure anything below 12.3V at the battery terminals after it has been charged all night with nothing connected to it then it is toast. My first cheapo battery that the manufacturer put in only lasted a year. Now I have an Optima and I'm going on three years (I did put in a four stage smart charger at the same time so that helped I'm sure). Also that reminds me. Check the water in your battery. If you have the original converter in your trailer from the factory then it will be slowly boiling your battery any time you are plugged in and don't have some load turned on in the trailer. The factory converters are really pretty bad on the batteries. Well that should be enough for now let us know if you figure out what is going on.
Old Oct 27, 2015 | 07:07 AM
  #1204
Snowseeker's Avatar
Snowseeker
I normally run the antifreeze threw the whole system Luckily my tank is just under the couch. So it only takes one gallon in the tank which I can lift to get all the antifreeze in the pickup corner of the tank then run the pump and every faucet and toilet.
Every year I think about blowing out the lines but this is just so much easier and no worries about a missed little spot of water somewhere.
Old Oct 27, 2015 | 09:10 AM
  #1205
Pwrgeek's Avatar
Pwrgeek
Put me in the blow them out category. I just hook up my compressor with the regulator turned way down and open things one at a time (making sure one is always open). Takes me about 10 minutes to get everything empty. By the way one of the biggest upgrades you can do if you are going to go this route is to change the caps on the low point drains out to some high quality brass ball valves.
Old Oct 27, 2015 | 12:52 PM
  #1206
WE3ZS's Avatar
WE3ZS
For winterization here I do both, first blow out with low pressure air and then use the factory supplied RV antifreeze connection to the water pump and fill the system that way which also fills the traps with AF and puts a little into the grey and black tanks to keep the valve seals wet. All this after I isolate and drain the water heater of course.
Old Oct 27, 2015 | 01:34 PM
  #1207
Excurvelle's Avatar
Excurvelle
This is my 2nd winter with the TT, last year I winterized and everything went fine. I dewinterized in Feb for a trip and before we came home I did a quick winterize at the campground by blowing air in the system and a little pink. When I went to use the camper in April the toilet valve and grey water gate valve had cracked.
Lesson learned, I will do what Tom says and run the pink through the system just to make sure I have everything.
Old Oct 27, 2015 | 01:50 PM
  #1208
az_r2d1's Avatar
az_r2d1
Air + the pink stuff is the most economical way to go. The air will get most of the water out and prevent diluting the pink stuff too much. You will also need less of the pink stuff.
You can buy an adapter to fit an airhose (7 bucks at wally world) or make your own.
There are several videos on youtube.
And don 't forget the outside shower and the washer/dryer connections !
Old Oct 27, 2015 | 02:05 PM
  #1209
Pwrgeek's Avatar
Pwrgeek
^^^^^ This.
Made that mistake the first year. Getting ready for the first trip of the second year turned the water pump on and had both outside showers start pouring water onto my driveway.
Old Oct 27, 2015 | 02:09 PM
  #1210
PSUhoss's Avatar
PSUhoss
That is exactly how I go about putting her up for the winter. Open the valve on the water tank, flip the valving to isolate the water heater, let it drain and use the water pump and RV non-toxic antifreeze connection to open the hot/cold valves one at a time. Don't forget the shower head and outside shower.
Also, don't forget to remove the water filter from the housing. The antifreeze will not displace all of the water in the filter and it will crack the housing if it happens to freeze.
We also dump a generous amount of windshield washer fluid down the traps and grey/black holding tanks. Cheap insurance.
It was a great summer and it is sad to see it come to an end. A couple more PSU football games and off to heated hibernation she goes for the winter!
Old Oct 27, 2015 | 02:10 PM
  #1211
az_r2d1's Avatar
az_r2d1
Originally Posted by Pwrgeek
^^^^^ This.
Yes common thing. They are hardly used so people forget.
Old Oct 27, 2015 | 02:41 PM
  #1212
Pwrgeek's Avatar
Pwrgeek
Yeah my fix was just to cap one of them off and replace the other one. We hardly ever use one of them and never used the other one.
Old Oct 27, 2015 | 04:55 PM
  #1213
mecdac's Avatar
mecdac
Question
I am thinking of "winterizing" mine by trading up.
Looking at Microlite 25DS by Flagstaff or Prime Time/Forest River Tracer Air both are 25' versions, front and rear door, 1 slide out.
I am leaning toward the Flagstaff from what I have read via reviews on the Tracer.
Old Oct 27, 2015 | 05:58 PM
  #1214
WE3ZS's Avatar
WE3ZS
Mark, if you move up to one of those larger trailers you may need to UPGRADE to a V-10 to handle the increased load.
Old Oct 27, 2015 | 06:02 PM
  #1215
ExxWhy's Avatar
ExxWhy
I just open the low point drains and let it gravity drain, bypass the hot water tank and drain that, then run 2 gallons of pink through all lines. I have a supply tank bypass so it's easy to get it all in.
