Now there's a guy with "enough truck"! Nice setup, hope you get to use it a lot!
I finally pulled the cover off mine and re-installed the batteries this week. Late this year. Hopefully the last season I'll need to cover it.
Finishing up a shed for the camper. 20ft wide x 48ft long x 16ft high. Has a 14ft x 14 ft door. Hope to have power and electric to it within the next few weeks. Enclosed in metal did not pour a concrete floor. Putting down Limestone base then 3ft wide conveyor belts. Wife works for a rock Quarry and can get the belts for free. So why not use them for a floor? 3ft wide 50ft long x 1/4" thick.
I could use that truck! I like it, what's something like that worth?
I had it listed on EBay and it did not sell. Reserve was set at $9000. Turned down $8200. and $8400. on it local. With some more work she would make a nice hauler truck.
But if it does not sell, I get to keep on enjoying it my self. Low Miles reman motor, New Carpet and stuff, All new belts and idler pulleys, New Radiator when motor was put in. I put lots of cash into it, fixing the screw up's someone else did on the belts and stuff.
Hope to pull the Sleeper floor out this year and put a new one in it. Replace wheel seals and stuff. Replace the AC line that is kincked and slowing down the coolant. And if I can get around to it, paint it back the factory color that is Brown. Paint is faded now and tired but being its from 1987. Guess its done its job.
It sold on Ebay for $9000. And I think if I had not had the buy it now button it would have went above that easy. Had 5 wanting it but one hit the buy it now button where the rest were bidding every day.
Pete
Hooking up Excursion tomorrow to the Camper, heading out on Wednesday. Found a cracked toilet valve yesterday that was leaking, had to run to the dealer (60 miles away) for a new one, they are going to try to warranty it but they say it probably froze.
I just installed airbags this weekend, once hooked up I can level the rig out instead of the TV being tail heavy.
Question, with air bags to you level than adjust weight distribution or adjust weight dist then level?
I set up with the bars then add the necessary air to level it out from there.
QUOTE=Excurvelle;15383471]Hooking up Excursion tomorrow to the Camper, heading out on Wednesday. Found a cracked toilet valve yesterday that was leaking, had to run to the dealer (60 miles away) for a new one, they are going to try to warranty it but they say it probably froze.
Question, with air bags to you level than adjust weight distribution or adjust weight dist then level?[/QUOTE]
On a different note, I had a customer come in on Friday who had their Blu Ox weight distributing shank shear off a few inches outboard of the 5/8" pin hole.
They broke it pulling into a nearby gas station, but they didn't bottom out "causing it to break"
