ATS 093 install thread
Old Mar 4, 2011 | 10:24 PM
  #91
wreckinball's Avatar
wreckinball
pulled up to a light and had another ford behind me and looked stroked, it was shaking and smoking and farted on take off. JK but yeah i rolled on and he stayed back a bit but i could tell he was trying. I turned into the gas station, GOTTA KEEP MY FOOT OFF THE BOOST haha, and he pulled in as well. Saw the stroke decal and laughed, he wasnt amused. He promptly asked me if i was chipped or modded, bwahahha. Yeah i said, have you seen my hood, theres lots of chips on it lol. Man i couldnt help it. he said that he wasnt sure why he wasnt keeping up with me since he is "chipped" at 300hp. me thinks ebay struck again hahahaha
Old Mar 4, 2011 | 10:27 PM
  #92
snaponprofile's Avatar
snaponprofile
Lol, isn't it so much fun now that you are turbo'd? I've been cooking chevys and new cars every since the turbo and man is it fun.
Old Mar 4, 2011 | 10:32 PM
  #93
wreckinball
7lbs of boost too, this weekend i am dialing in 10 to see if it makes a diff. Think it will?
Old Mar 4, 2011 | 10:38 PM
  #94
snaponprofile
Yeah, you should notice one.
Old Mar 4, 2011 | 10:42 PM
  #95
wreckinball
haha, just hope it lasts long enough for me new fender decals to be completed! lol. so tomorrow i crank and twist, should be interesting. Did you know that the ford 7.3 tech actually told me i would be okay to push my truck to 18 but keep it under 18? i called asking about wastegates and he was like, yeah bro i adjust them all the time for people. bring er in. hmmmmm
Old Mar 4, 2011 | 11:12 PM
  #96
94 smokin stroker's Avatar
94 smokin stroker
Wow you guys dont see 1100 just driving gosh guys somethings wrong with my truck then my pyro hits 1000 by 55-60 when i lay on it unloaded and touches 600 just cruising no smoke though ip not up and ip and injectors are fine no white smoke or rough running but of course a clogged airfilter may have a little to do with it
Old Mar 4, 2011 | 11:17 PM
  #97
wreckinball
i have to have the pedal to the floor to hit 800 now and thats on a 12% grade. Going 60mph in a 4.10 C6 setup gets hot but never over 800 anymore. Fuel was a bit high. What is your intake and exhaust like?
Old Mar 5, 2011 | 07:39 AM
  #98
snaponprofile
Turn your IP down a bit and you EGT's should go down. Mine is around 300-400* cruising.
Old Mar 5, 2011 | 09:07 AM
  #99
Coalroller's Avatar
Coalroller
id have to say mine are right about the 400-500* when cruising but my pump (old one) is almost completely maxed out (stock injectors too)... hence the reason for new injectors and pump haha. But yeah even loaded up hill i still have never hit over 1100* and im taklkin steep garde
Old Mar 5, 2011 | 02:06 PM
  #100
wreckinball
okay so my wastegate is pinned to its location. I cant turn it because there are two indents in the side that has the hole on it. here is a pic with identification. It feels like it will twist in half if i turn any harder......thoughts?
Old Mar 5, 2011 | 02:11 PM
  #101
joe f350's Avatar
joe f350
buy a new one thats what i did for dectichops truck this is the one i bought
T3 T4 Turbo Single Port Wastegate Actuator 90 Degree - eBay (item 160371483192 end time Mar-14-11 17:23:50 PDT)
Old Mar 5, 2011 | 03:16 PM
  #102
Coalroller's Avatar
Coalroller
Wreck dont try to do it on the truck... take it and put it in a vice and use either a good set of channel locks or a really good set of vice grips... Also spray some penetrating lube on it and let it soak a while
Old Mar 5, 2011 | 03:32 PM
  #103
snaponprofile
If I remember correctly, dectichop broke his trying to adjust it.
Old Mar 5, 2011 | 04:05 PM
  #104
Coalroller's Avatar
Coalroller
thats why a vice, penetrating lube (PB blaster) and good tools come in handy
Old Mar 5, 2011 | 05:02 PM
  #105
wreckinball
It's not stuck from corrosion, it indented like I was showing in the pic. It will turn a bit but I don't want to break it. If chop broke his I know why.
