ATS 093 install thread
Old Mar 25, 2011 | 05:16 PM
  #226
91dirtydiesel's Avatar
91dirtydiesel
Actully that helps quite a bit. Man I think you just need to come help me with it, id have no clue how if it wasn't for this site!! Thanks for the info yet again!!
Old Mar 25, 2011 | 08:13 PM
  #227
wreckinball's Avatar
wreckinball
think how i got the information, all the help of brother on this site with smarts and experience! Glad to pass it along, if i was a bit closer or there wasnt a 100 dollar ferry id drop by!
Old Mar 25, 2011 | 10:27 PM
  #228
OrFordGuy's Avatar
OrFordGuy
have to ask what ios a cdr?????
Old Mar 25, 2011 | 10:41 PM
  #229
wreckinball
crankcase depression regulator. little tuna can on the back of IDI's intake manifold.
Old Mar 25, 2011 | 11:06 PM
  #230
OrFordGuy's Avatar
OrFordGuy
so thats on all I.D.I.s or does it come with a turbo kit....
Old Mar 25, 2011 | 11:09 PM
  #231
wreckinball
all idi's bro. the turbo just relocates it.
Old Mar 25, 2011 | 11:19 PM
  #232
OrFordGuy's Avatar
OrFordGuy
rodger that will either relocate or replumb as required in my install...supposei could plumb it into the snail intake hat after i build it...
Old Mar 25, 2011 | 11:39 PM
  #233
Phy's Avatar
Phy
The snail hat is pressurized. You need to plumb it in before the turbo...
Old Mar 25, 2011 | 11:46 PM
  #234
wreckinball
what turbo system do you have?
Old Mar 25, 2011 | 11:51 PM
  #235
OrFordGuy's Avatar
OrFordGuy
h ok i'll plumb it into intake tube between the filter and turbo....is it normally mounted to the valve cover???? and don't have a turbo kit, i'm building my own setup as the original type setup will not fit my cab/engine configuration....
Old Mar 26, 2011 | 12:38 PM
  #236
Phy's Avatar
Phy
The CDR performs the same function as a PCV valve on a gasser. It's so big because without a throttle valve, a diesel doesn't make as much vacuum as a gas engine.
The CDR's inlet (the port on the curved edge) needs tp be plumbed to the valley cover, or valve cover, or anywhere else that's connected to crankcase vapor. The outlet (on the flat side) needs to be connected to the intake anywhere upstream of the turbo.
The NA engines came with it mounted at the rear of the manifold. The turbo engines came with it on the valve cover.
Old Mar 26, 2011 | 12:58 PM
  #237
OrFordGuy's Avatar
OrFordGuy
cool thats kinda what i thought... will look for it when i'm at the yard today...may have scored a blown up 7.3 with banks sidwinder setup... local fte guyfrom rainer has one blowed up nice truck and one turbod donor truck.. needs motor swapped...i can keep motor and turbosetup...thought i'd put the heads and turbo setup on my 6.9...still negotiating though so i'll see what happens...
Old Apr 19, 2011 | 08:50 PM
  #238
nibiru's Avatar
nibiru
Say Wreckinball:
sorry to be so short - right in the middle of installing new injector pump - got the ATS installed - looking for some insight into how you ran your injector return lines - did you take a foto - ?
I'll go thru all 16 pages here a bit later after I loose the rest of the light
cheers thanks in advance
Old Apr 19, 2011 | 09:08 PM
  #239
therifleman556's Avatar
therifleman556
I routed the number seven line up to the filter head and the number one back to the block leading back to the tank, instead of seven going to the block-to-tank and one going to the filter head- worked fine. I think wreckinball went seven to the block but ran it in front of the intake neck.
Old Apr 19, 2011 | 09:55 PM
  #240
nibiru's Avatar
nibiru
say therifleman556
Cheers for the fast reply - makes sense
Now - 2 new questions - on the lifting hook now removed ( mounted near no.7 piston ) there was a stud bolt - insight as to where now to place this to mount the wire loom keeper
second question - the glow plug controller gets moved top of valve cover between 3 and 5 injector - when mounted at rear of motuer it was grounded to a stud bolt back of intake manifold no 8 piston - should the stud bolt from lifting hook near no 7 be moved and used to ground glow plug controller - somewhere between no 3 and 5 ?
cheers in advance
