New 71
(Jacksboro). He musta sold SC Steering to Duff’s?
I would like to do the TRO (Just flip the linkage). I had the steer linkage from my ’70 over to a local machinist who’s put adjusters on a
2nd end and in the top rod for more adjustability. He’s never in (lives between several farms and is all ways @ 1 of these neighbors due
to havin the shop) & I cant get it onto the ’77 frame altho done several yrs now...
I dont think I’ll go “extreme” anything. Retiring rig from 70% off rd / 30% on to the opposite & leavin to my 26 y/o daughter. No cross/hi steer,
no rod end, big bar linkage. I may 2* ream the knuckles right on the rig altho my machinist background sez ah, ah, ahhh. Dont U drop in some
kinda cheb spacer/bushing THEN lay in the rod end? Like said not seeking heim joints.
Then I cut a path to the creek crossing.
Once I get it fired up I'll do a w/engine running w/power steering steering linkage (full range of motion) check. Making sure my knuckle stops are set correct so I do not exceeded the u joint range of motion and make sure nothing else is binding up. Then set the steering damper so it is working as it should.
Put the front tires back on and take it for a test drive and then function check the new lock in/outs. Maybe do a little flex check on something out in the back yard. Also have to put my sector shaft pitman arm end skid plate back on. And clean up the mess in my shop.
Then I hit a big rock in a very narrow steep V trail whipped the steering (again NO damper and almost broke my thumb. YES I normally wheel "thumbs out"). But still managed in the blink of an eye to free spin the system and bottom out the worm gear hit and split the thin aluminum end cap almost in half. Dumped my Sag p/s box fluid every where. I have since got a 1" thick end cap, got it and the top cap drilled and tapped so I can run hydro assist steering some day.
Where I got my idea to flex brace the steering box. Yes easy to do when nothing is on the front of the Bronco.
Since you have easy excess to your frame and that is a known weak area, you might think about doing this. Double plate the inside and add a gusset.
Also think about trac bar gussets while you are there welding. https://www.broncitisparts.com/produ...rac-bar-gusset
That is my next upgrade, I am still rocking the trail side weld repair. It looks UgLy as sin, but it is holding like a rock star so it is staying. Until I add the hydro assist and add a Kiser Riser to the axle tube.
