..................Tech Folder..............
TECH FOLDER
Check back...we update often :-D --------------------------------------------------------------------- How to post pictures: Adding pictures to threads. ---------------------------------------------------------------------- Sensor and Actuator data vs output voltage. Click Here Thanks Bismic ------------------------------------------------------------------------------------------------------------ Frame Mounted Third Battery. Installation Thanks WatsonR ------------------------------------------------------------------------------------------------------------ New 11/2017 (5R110 transmission Cold fluid exchange) Home shop flush Thanks, Syncrosmash --------------------------------------------------------------------- STC/HPOP Removal/Install with Tips & Pic's Step by Step Guide Thanks, silverbullet6oh --------------------------------------------------------------------- Scan Gauge 2 SYNC CODES View Single post Thanks, BLADE35 --------------------------------------------------------------------- Questions or thinking of buying a used 6.0L truck? Click here Thanks, Bismic --------------------------------------------------------- 2008/2009 Wiring Pigtail Kit Identification Catalog PDF1 PDF2 --------------------------------------------------------------------- Index Of Ford Manuals PDF Manuals Our list has grown! If you have a manual to contribute contact us. --------------------------------------------------------------------- 6.0L head lifting bracket.... Build your own! Thanks, Lilpooh ------------------------------------------------------------------------------- Trobuleshoting Coolant loss Checklist Thanks, Bismic Powerstroke Cooling System Flush Overview and Flush PDF Thanks, Nylyon Coolant Flush, Change Discussion and Instructions Thanks, 03-6L-X, beachbumcook, and 69cj BELT TENSIONER TOOL, Fabrication Article Click Here Thanks Arizona97 ---------------------------------------------------------------------- Testing Injector Harness and Coils Click Here Thanks, Bismic FICM TEST Procedure Click Here Thanks, Bismic FICM How to FICM Guide Thanks, pstrang Detailed FICM Repair Procedure Thanks, DrQuad FICM Connector How To Repair Procedure Thanks, Fixxxer-upper Battery Cables Improving battery cables for battery life. Thanks, TooManyToys Camshaft Position Sensor (CMP) Wiring Pigtail replacement Thanks, dchamberlain Crankshaft Position Sensor Removal/Installation Thanks, SmackDaddy --------------------------------------------------------------------- Ford Manuals in PDF Click Here Head Bolt torque sequence change New Specifications PDF Recommended Readings - Temperature & Pressure Click Here Thanks, Bismic Additional PDF Help links Click Here Thanks, smokersteve --------------------------------------------------------------------- Troubleshooting a "low power" condition Check List Trouble Shooting a No Start Condition Check List Thanks, Bismic --------------------------------------------------------------------- Stiction Fix Must read, Instruction and Video Thanks, BLADE35 Injector Top O-Ring/Seals The Whole Story Thanks, creator Injector Questions and Answers Injectors Explained Thanks Bismic Changing Injectors https://www.ford-trucks.com/forums/5...ml#post4355612 Thanks to Matt -------------------------------------------------------------------------- Super Duty FAQ Super Duty FAQ's 6.0 fix for various running problems 6.0 fix for various running problems...Must Read! - Ford Truck Enthusiasts Forums Diagnosing 6.0L Oil Leaks FIX ANY 6.OL LEAK By Wyatt66f100 Thanks Wyatt66f100 Recomendations for New to me owner of a used truck Checklist: Thanks, Texastech_diesel --------------------------------------------------------------------- Turbo Up-Pipe Exhaust Leak Fix Thanks, Holdendaniels --------------------------------------------------------------------- VGT Turbo ABC's Turbo Information Thanks to Brickie and Bismic VGT Turbo Rebuild Step by Step Instructions Thanks, Benchwrench --------------------------------------------------------------------- Upgrade Torqshift Transmission filter 2008+ Filter & Pan Thanks, diesel dan Torqshift Shift Relearning Strategy Torqshift Shift Relearning Strategy Thank you Bismic… TorqShift Transmission Information and Troubleshooting Thanks, Bismic TorqShift P0713 TFT Sensor Failure Replacement Procedure Thanks, Unrealo4 --------------------------------------------------------------------- Electonic Shift on the Fly (ESOF) Discussion & Trouble Shooting Thanks, dchamberlain ---------------------------------------------------------------------- EGR Disconnect Instructions EGR Disconnect Instructions - Ford Truck Enthusiasts Forums And Cleaning Scary pics of my 11,000 mile-old EGR valve - Ford Truck Enthusiasts Forums Brought to you buy t_b EGR O-Ring Ford Part Number Egr-o Ring Ford Part# Is - Ford Truck Enthusiasts Forums Thanks to eight301 EGR Cooler Hose Discussion & Procedure Thanks to everyone, Blade35, amdriven2liv, Bismic --------------------------------------------------------------------- 2003 & Early 2004 ICP (Injection Control Pressure Sensor) Must Read Discussion on ICP, No start problems Includes Part Numbers and removal proceedures Thanks to all who participated 03/ Early 04 ICP Swap Thanks, william_04_x ---------------------------------------------------------------------- Water Pump Replacement Thanks, fixxxer-upper ---------------------------------------------------------------------- Crankcase Ventilation Rerouting Crankcase Ventilation Rerouting - Ford Truck Enthusiasts Forums Thank You Riggz --------------------------------------------------------------------- Inter-cooler hose clamp Intercooler hose clamp - Ford Truck Enthusiasts Forums --------------------------------------------------------------------- Powerstroke 6.0 L Technical Intro Manual Powerstroke 6.0L Technical Intro Manual or 6.0L Bible Table of Contents pdf '05 PSD Update to Powerstroke 6.0 L Technical Intro Manual International Truck & Engine Corporation Publication Features, Descriptions, Unique Service Procedures, and General Diagnostics of the 6.0L DIT Power Stroke Thanks, Brickie --------------------------------------------------------------------- 6.0 in very cold climate Newbie considering 6.0 in cold climate - Ford Truck Enthusiasts Forums --------------------------------------------------------------------- Small Hint For Flash Programmer UsersSmall Hint For Flash Programmer Users - Ford Truck Enthusiasts Forums Thanks Matt ---------------------------------------------------------------------- Controller Area Network Explained Controller Area Network Explained - Ford Truck Enthusiasts Forums and again thanks Matt --------------------------------------------------------------------- High Idle Mod 2003-2004 Click Here 2005-2006 Diesel Stop.com Thank you hitecdan --------------------------------------------------------------------- UpFitter Switch wiring Click Here 2005 upfitter realy panel location?????? - Ford Truck Enthusiasts Forums ---------------------------------------------------------------------- Engine Idle Control Engine Idle Control - Page 6 - Ford Truck Enthusiasts Forums Thank you me1mckee and JimReitz... ----------------------------------------------------------------------- Body Builders Guide - includes PTO, snowplows, body sizes etc. Advisory Service ----------------------------------------------------------------------- Change the Air Filter Air Filter Thank you Bismic… --------------------------------------------------------------------- 6.0L Engine Oil change CHANGING ENGINE OIL Thank you Bismic --------------------------------------------------------------------- HFCM Filter Change and Fuel/Water Separator Drain Procedure FUEL/WATER SEPARATOR DRAIN PROCEDURE Thank you Bismic Upper Fuel Filter, Engine Changing Upper Fuel Filter HFCM Water Separator Drain Plug Upgrade PLUG INSTALL Fuel Pressure Regulator Udate Kit Blue Spring Install Thanks, Rusty Axlerod Fuel Pressure Gauge Installation Procedure Thanks, texastech diesel --------------------------------------------------------------------- Battery Disconnect —Dual Battery Disconnect - Dual Thank you Bismic --------------------------------------------------------------------- How to Harpoon the fuel tank Harpoon The Tank? - Ford Truck Enthusiasts Forums Thank you Bob --------------------------------------------------------------------- Engine Break in breaking in the 6.0L - Ford Truck Enthusiasts Forums ---------------------------------------------------------------------- Tow/Haul mode on start-up mod TOW/HAUL- any way to set as start up default??? - Page 3 - Ford Truck Enthusiasts Forums Thank you me1mckee... ---------------------------------------------------------------------- Mirror Swap '03 Mirror Swap - All Done! - Ford Truck Enthusiasts Forums Thanks to Rick "Karic"... ----------------------------------------------------------------------- Missing Items on the Super Duty Missing Items on the Super Duty - Ford Truck Enthusiasts Forums Thank you 04FordHarleyF250 ------------------------------------------------------------------------- Tractive Force graph Tractive force graph (contains photos) - Ford Truck Enthusiasts Forums Thanks to me :-D -------------------------------------------------------------------------- 2002/2005 F-250/350 Proper Foglight Operation/ SUVLIGHTS Harness Fix Thanks to big ride and 4X4 IN REFUGIO -------------------------------------------------------------------------- Block heater cord routing Diesel Technician Society Cord part number at International: Z3500043 Marinco Bumper Plug Installation Thanks, EXbowtieguy -------------------------------------------------------------------------- Ball Joint replacement How to replace your Super Duty Ball Joints - Ford Truck Enthusiasts Forums Thanks to RacerGuy -------------------------------------------------------------------------- Transfer Case, Power Steering, Differential Oil Additional Maintenance not addressed in Tech - Ford Truck Enthusiasts Forums Thanks to Bear Hunter Elimination of Door Chime Elimination of Door Chime - Ford Truck Enthusiasts Forums Thanks to kb1aah -------------------------------------------------------------------------- MPH Speedo Calculator For Variable Tire Sizes Speedometer Calibration Calculator And Information -------------------------------------------------------------------------- DIY Coolant Filter Information for the home built Coolant filter Thanks to Diesel Dan and the rest who contributed __________________________________________________ ______________ |
Instrument Cluster / Battery Altern ABS / Parking Brake Light / Illumination Issues Electrical Checklist and Tips
Thanks to gearloose1 -------------------------------------------------------------------------- Always bright overhead display: billgart.com - Lighting Thanks for the find Customz -------------------------------------------------------------------------- Greasing the driveshaft slip joint: Slip joint regreasing Thanks again to Customz -------------------------------------------------------------------------- Fuel Gauge (Gage) / Level - Read post # 7 Gas Guage - Ford Truck Enthusiasts Forums Thanks to Hayapower! -------------------------------------------------------------------------- Reprogramming "Flash" Procedure For Techs Hey kw.... - Ford Truck Enthusiasts Forums Post # 13 Thanks vloney & huntercgr -------------------------------------------------------------------------- 6.0 Updates from Various Model Years https://www.ford-trucks.com/forums/5...ml#post3974497 2006 6.0L Diesel Power Stroke Cylinder Head Commonization Ford Truck Enthusiasts Forums - View Single Post - Differences between new 6.0 an old 6.0 -------------------------------------------------------------------------- Great Lie-O-Meter Explaination Post # 2 https://www.ford-trucks.com/forums/5...ml#post3990543 Thanks Matt. -------------------------------------------------------------------------- CJ4 rated oil, from API...See Post # 19 https://www.ford-trucks.com/forums/5...ml#post4014847 Special Thanks To mrxlh -------------------------------------------------------------------------- OEM Oil and Fuel Filters... What To Look For https://www.ford-trucks.com/forums/5...ml#post4145955 Thanks to Beachbumcook...Great research. __________________________________________________ _________________ Transfer Case Fluid change Welcome to guzzle's Transfer Case Fluid Change Web Page Thanks to Customz for finding __________________________________________________ _________________ SRW rear differential fluid change Welcome to guzzle's Rear Differential Maintenance Web Page Thanks to Customz for finding __________________________________________________ _________________ Front differential fluid change Welcome to guzzle's Front Differential Maintenance Web Page Thanks to Customz for finding __________________________________________________ _________________ Replacement brake rotors and pads Welcome to guzzle's Powerslot/Hawk pads brake Maintenance Web Page Thanks to Customz for finding -------------------------------------------------------------------------- Fabricated Aux. Fuel Tank https://www.ford-trucks.com/forums/5...lly-sorry.html Thanks to bczolone...Nice Work! -------------------------------------------------------------------------- Tips to prevent common probelms https://www.ford-trucks.com/forums/7...-problems.html Thanks to bismic :-X22 --------------------------------------------------------------------------- Heated Seats Indicator https://www.ford-trucks.com/forums/7...ndicators.html Thanks to Benchwrench --------------------------------------------------------------------------- Most asked Question: Best Mods for my truck? --------------------------------------------------------------------------- Keyless Entry Code Keypad code & functions Thanks to Jnobles06 --------------------------------------------------------------------------- |
