Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 vanSPONSORED BY:
Closed Thread
  #1 (permalink)
Old 11-04-2004, 08:38 PM
IB Tim's Avatar
IB Tim IB Tim is offline
Site Administrator
1989 Swift DB4
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
..................Tech Folder..............
TECH FOLDER
Check back...we update often
Index Of Ford Manuals PDF Manuals
Our list has grown! If you have a manual to contribute contact us.
Trobuleshoting Coolant loss Checklist
Thanks, Bismic
Powerstroke Cooling System Flush
Overview and Flush PDF
Thanks, Nylyon
Coolant Flush, Change
Discussion and Instructions
Thanks, 03-6L-X, beachbumcook, and 69cj
FICM TEST Procedure Click Here
Thanks, Bismic
FICM How to FICM Guide
Thanks, pstrang
Detailed FICM Repair Procedure
Thanks, DrQuad
FICM- Fuel Injection Control Module Guide
Description, Diagnostics, Operation
FICM Connector How To Repair Procedure
Thanks, Fixxxer-upper
Ford Manuals in PDF Click Here
Head Bolt torque sequence change New Specifications PDF
Recommended Readings - Temperature & Pressure Click Here
Thanks, Bismic
Ford OBD-II Diagnostic PDF Trouble Code Definitions
Thanks, 69cj
Additional PDF Help links Click Here
Thanks, smokersteve
Powerstroke diagnostic trouble codes
Ford OBDII Diagnostic Trouble Codes - Powerstroke Diesel Codes .: Articles
2006-2007 Diagnostic Codes PDF
Troubleshooting a "low power" condition
Check List
Trouble Shooting a No Start Condition
Check List
Thanks, Bismic
Injector Questions and Answers
Injectors Explained
Thanks Bismic
Changing Injectors
http://www.ford-trucks.com/forums/57...ml#post4355612
Thanks to Matt
Diagnosing 6.0L Oil Leaks
FIX ANY 6.OL LEAK By Wyatt66f100
Thanks Wyatt66f100
Turbo Up-Pipe Exhaust Leak Fix
Thanks, Holdendaniels
VGT Turbo ABC's Turbo Information
Thanks to Brickie and Bismic
VGT Turbo Rebuild Step by Step Instructions
Thanks, Benchwrench
Torqushift Shift Relearning Strategy
Thank you Bismic…
TorqShift Transmission Information and Troubleshooting
Thanks, Bismic
TorqShift P0713 TFT Sensor Failure Replacement Procedure
Thanks, Unrealo4
Electonic Shift on the Fly (ESOF) Discussion & Trouble Shooting
Thanks, dchamberlain
EGR Disconnect Instructions
EGR Disconnect Instructions - Ford Truck Enthusiasts Forums
And Cleaning
Scary pics of my 11,000 mile-old EGR valve - Ford Truck Enthusiasts Forums
Brought to you buy t_b
EGR O-Ring Ford Part Number
Egr-o Ring Ford Part# Is - Ford Truck Enthusiasts Forums
Thanks to eight301
EGR Cooler Hose Discussion & Procedure
Thanks to everyone, Blade35, amdriven2liv, Bismic
6.0 fix for various running problems
6.0 fix for various running problems...Must Read! - Ford Truck Enthusiasts Forums
2003 & Early 2004 ICP (Injection Control Pressure Sensor)
Must Read Discussion on ICP, No start problems
Includes Part Numbers and removal proceedures
Thanks to all who participated
03/ Early 04 ICP Swap
Thanks, william_04_x
Water Pump Replacement
Thanks, fixxxer-upper
Crankcase Ventilation Rerouting
Crankcase Ventilation Rerouting - Ford Truck Enthusiasts Forums
Thank You Riggz
Inter-cooler hose clamp
Intercooler hose clamp - Ford Truck Enthusiasts Forums
Powerstroke 6.0 L Technical Intro Manual
Powerstroke 6.0L Technical Intro Manual
or
6.0L Bible Table of Contents
'05 PSD Update to Powerstroke 6.0 L Technical Intro Manual
2005 6.0L Bible Update Table of Contents
International Truck & Engine Corporation Publication
Features, Descriptions, Unique Service Procedures, and General Diagnostics of the 6.0L DIT Power Stroke
Thanks, Brickie
Super Duty FAQ
Super Duty FAQ's
6.0 in very cold climate
Newbie considering 6.0 in cold climate - Ford Truck Enthusiasts Forums
Small Hint For Flash Programmer
UsersSmall Hint For Flash Programmer Users - Ford Truck Enthusiasts Forums
Thanks Matt
Controller Area Network Explained
Controller Area Network Explained - Ford Truck Enthusiasts Forums
and again thanks Matt
High Idle Mod 2003-2004 Click Here
2005-2006 Diesel Stop.com
Thank you hitecdan
UpFitter Switch wiring Click Here
2005 upfitter realy panel location?????? - Ford Truck Enthusiasts Forums
Engine Idle Control
Engine Idle Control - Page 6 - Ford Truck Enthusiasts Forums
Thank you me1mckee and JimReitz...
Body Builders Guide - includes PTO, snowplows, body sizes etc. Advisory Service
Change the Air Filter
Air Filter
Thank you Bismic…
6.0L Engine Oil change
CHANGING ENGINE OIL
Thank you Bismic
HFCM Filter Change and Fuel/Water Separator Drain Procedure
FUEL/WATER SEPARATOR DRAIN PROCEDURE
Thank you Bismic
Upper Fuel Filter, Engine
Changing Upper Fuel Filter
HFCM Water Separator Drain Plug Upgrade
PLUG INSTALL
Fuel Pressure Regulator Udate Kit Blue Spring Install
Thanks, Rusty Axlerod
Battery Disconnect —Dual
Battery Disconnect - Dual
Thank you Bismic
How to Harpoon the fuel tank
Harpoon The Tank? - Ford Truck Enthusiasts Forums
Thank you Bob
Engine Break in
breaking in the 6.0L - Ford Truck Enthusiasts Forums
Tow/Haul mode on start-up mod
TOW/HAUL- any way to set as start up default??? - Page 3 - Ford Truck Enthusiasts Forums
Thank you me1mckee...
Mirror Swap
'03 Mirror Swap - All Done! - Ford Truck Enthusiasts Forums
Thanks to Rick "Karic"...
Missing Items on the Super Duty
Missing Items on the Super Duty - Ford Truck Enthusiasts Forums
Thank you 04FordHarleyF250
Tractive Force graph
Tractive force graph (contains photos) - Ford Truck Enthusiasts Forums
Thanks to me
2002/2005 F-250/350 Proper Foglight Operation/ SUVLIGHTS Harness Fix
Thanks to big ride and 4X4 IN REFUGIO
Block heater cord routing Diesel Technician Society
Cord part number at International: Z3500043
Marinco Bumper Plug Installation
Thanks, EXbowtieguy
Ball Joint replacement
How to replace your Super Duty Ball Joints - Ford Truck Enthusiasts Forums
Thanks to RacerGuy
Transfer Case, Power Steering, Differential Oil
Additional Maintenance not addressed in Tech - Ford Truck Enthusiasts Forums
Thanks to Bear Hunter
Elimination of Door Chime
Elimination of Door Chime - Ford Truck Enthusiasts Forums
Thanks to kb1aah
MPH Speedo Calculator For Variable Tire Sizes
Speedometer Calibration Calculator And Information
DIY Coolant Filter
Information for the home built Coolant filter
Thanks to Diesel Dan and the rest who contributed
__________________________________________________ ______________
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
  #2 (permalink)
Old 07-04-2006, 12:01 AM
kw5413's Avatar
kw5413 kw5413 is online now
Fortune Favors The Brave
2010 Lincoln MKT
kw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputation
Instrument Cluster / Battery Altern ABS / Parking Brake Light / Illumination Issues Electrical Checklist and Tips
Thanks to gearloose1
Always bright overhead display: billgart.com - Lighting
Thanks for the find Customz
Greasing the driveshaft slip joint: Slip joint regreasing
Thanks again to Customz
Fuel Gauge (Gage) / Level - Read post # 7
Gas Guage - Ford Truck Enthusiasts Forums
Thanks to Hayapower!
Reprogramming "Flash" Procedure For Techs
Hey kw.... - Ford Truck Enthusiasts Forums Post # 13
Thanks vloney & huntercgr
6.0 Updates from Various Model Years
http://www.ford-trucks.com/forums/52...ml#post3974497
2006 6.0L Diesel Power Stroke Cylinder Head Commonization
Ford Truck Enthusiasts Forums - View Single Post - Differences between new 6.0 an old 6.0
Great Lie-O-Meter Explaination Post # 2
http://www.ford-trucks.com/forums/53...ml#post3990543
Thanks Matt.
Resident Diesel Technicians
http://www.ford-trucks.com/forums/52...ml#post3998872
CJ4 rated oil, from API...See Post # 19
http://www.ford-trucks.com/forums/53...ml#post4014847
Special Thanks To mrxlh
OEM Oil and Fuel Filters... What To Look For
http://www.ford-trucks.com/forums/54...ml#post4145955
Thanks to Beachbumcook...Great research.
__________________________________________________ _________________
Transfer Case Fluid change
http://www.guzzle.rbmicro.com/transfer.html
Thanks to Customz for finding
SRW rear differential fluid change
http://www.guzzle.rbmicro.com/rdiff.html
Front differential fluid change
http://www.guzzle.rbmicro.com/fdiff.html
Replacement brake rotors and pads
http://www.guzzle.rbmicro.com/pshawk.html
Fabricated Aux. Fuel Tank
http://www.ford-trucks.com/forums/58...lly-sorry.html
Thanks to bczolone...Nice Work!
Tips to prevent common probelms
http://www.ford-trucks.com/forums/70...-problems.html
Thanks to bismic
Heated Seats Indicator
http://www.ford-trucks.com/forums/79...ndicators.html
Thanks to Benchwrench
Most asked Question: Best Mods for my truck?
Keyless Entry Code Keypad code & functions
Thanks to Jnobles06
__________________
"You're doing a lot of choppin', but no chips are flyin'." - Foghorn Leghorn
"I am not afraid of death. It is the process of dying that bothers me."
Book of kw5413, Chapter 2012 Verse 05:17
Closed Thread
Tags
2003, 2004, 60, 60l, auxiliary, change, f250, f350, flush, ford, fuel, install, manual, oil, power, steering, switch, tank, technician, upfitter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
