- Itake manifold - 351C
- '77 351m and thick white smoke
- Coatings of engine parts
- 351M-400 Harmonic Balancers
- Best Approach to Avoid Pinging?
- correction for threads on valve adj on comp cam
- Error/Typo Found in Engine ID Information
- bad lifter and cam problem need advice
- 400 Engine Project update
- 351 and 400 same after all
- fredloves400-oilpan question
- Oil Deflectors--Where to buy?
- Re Use Valley Pan gasket? and oil leak?
- Kaase wins 2nd consecutive Engine Masters
- pop in upper rpm's when heavy on the gas
- warning light
- Rebuild Gasket Sets?
- 351m identification help
- fenderwll exit headers
- 79 f-250 2wd no start
- Cam for 351 Cleveland
- Equal length hedders
- 1971 distributor & engine specifications for the 400
- 400 Stroker Question
- back firing up thru carb please help!
- Rocker install and adjsutment question
- kwitcherwhinin' (about alloy M heads :D)
- fly wheel
- pulley for 400
- 351m oil leak
