New 400 is in, all ready to fire up once I get the headers in this week.
Primed her with an old dizzy shaft on a dril a few times. Now that she is together, I was fooling with it turning it over( had to make the electronic ignition harness this weekened)...
Before I run it I wanted to know if there is any special procedure I should follow as far as torquing the rockers down. I've turned it over a few times making sure the valves are fully closed..then just made the rockers wrist tight ( stupid torque wrech doesn't read down to 18-25 ft lbs) on all of them . Left the valve covers loose so when I fire it up I can adjust as needed. Nothing seems out of whack or overly tight/loose as it stands. Just wondering what may happen once the lifters pump up.
I was told to get the tight enough so they didnt come off. After i replaced my lifters & push rods & got the rockers tight I havent had to mess with them.
fordfury is correct, if you have stock rockers don't run it with them loose. They're designed that way. If you run with them loose you could break the 5/16" bolts &/or ruin the threads in the heads.
Fired it up tonight ( finally)... seems to be fine. I will borrow a buddies low ftlbs wrech tomorrow and just re check them ( as well as the new headers and intake once I can let it warm up .
Need to install the front clip, rad etc etc.. before I can run it for more then 10-15 seconds.
i retorqued my headers four times before they held the same torque value, and i never had a leak with them id drive it for a little bit torque them let it cool down then drive it torque them let it cool and so on tell i thought they were good, just dont break any bolts.
