- 2000 Sport V6 to V8 swap info needed!!!!!
- Slip Yoke lube process
- speed limiter
- O2 sensor
- No Heat, No A/C...No BLOWING
- Who has has or is having a blend door problem?
- Does the dealer provide alternative timing programs for the ECM?
- 94 Explorer check engine light
- More questions! Perf. and Maint. related...
- Loosening high torque bolts
- '91 "check engine" light;how to get codes, .learn meaning, repair?
- Explorer clunk noise? Gas mileage? Lots of ?
- Transmission pan help- 99 Sport
- '97 XLT Diff Problems
- 98 Ford Explorer 4.0L with PATS anti-theft system
- trans problem!!!! NNEEEDDDD HHHEEELLLPPPP!!!!
- Remote for a 95 Explorer
- 2000 Explorer front brake pad replacement
- power windows (clicking sound)
- 94 Explorer surging at idle, cruising, etc.
- Coolant leak from freeze plug
- Help w/ rims
- 2000 V6 Explorer - Where's the horn?
- Any pics of Custom rims on a 1995 explorer
- Engine light, mileage drop, change in high-pitched whine--related?
- Clunking & grinding noise in 4wd
- 1st Gen explorer
- 1994 Explorer overheating
- Explorer M5OD Wasted.....
- 94' Explorer A/C is always on
