View Full Version : 1994.5 - 1997 7.3L Power Stroke Diesel
- The slowest build thread, ever
- Creaking while turning/flexing
- Cab hitting transfer case?!?
- Another E40D T/S thread
- crankshaft spins but engine does not
- 97 powerstroke start, stall then no start.
- Cold start problems 95 7.3
- 1997 F250 HD, extended cab, XLT,Mounts
- 1996 7.3L lots of white smoke and power loss
- White smoke and stumbling at wot
- Motorcraft SD valve cover gasket disappointment.
- Rear main seal?
- Super duty top end on OBS long block
- Head casting numbers, do they matter?
- 4r100 to obs pump conversion help
- Weird clutch issue!
- 97 F350 no start sometime, clicking blinking, missing
- Small idle surge
- Check engine light
- 97 350 build option/questions
- Strange Noise, maybe Transmission? '95 E350 7.3L
- 2002 7.3L turbo will it fit on my 1997 7.3
- Aftermarket front sway bar options 97 f 350
- Bad Miss after sitting, Code Reader
- 10.25 Gears into a 10.5
- Tmp sensor. Are there two possible sensors?
- Paint questions
- My OBS refresh/build
- P1272 and P1274 Combo
- HELP! Bench Starting 7.3
