Head casting numbers, do they matter?
Old Nov 25, 2019 | 06:22 PM
afmedic's Avatar
afmedic
Like the title says, do they matter? My head has 1825113c1. I found a head for sale for a good price to rebuild, but the number is 181303c . Do they matter? I have found several sites for heads and none of them specify a casting number or even ask for on . Were there different coolant or oil passages? Can I use it or should I pass on it.
Thanks for the help!
Old Nov 25, 2019 | 06:45 PM
nateairman's Avatar
nateairman
As long as the head is for a 7.3 powerstroke not an IDI I think you would be okay.
Old Nov 25, 2019 | 06:47 PM
afmedic's Avatar
afmedic
It's off of a 1995 7.3 so it should be good. The engine was running and he bought it for the timing cover and turbo. He is trying to sell the rest
Old Nov 25, 2019 | 07:54 PM
nateairman's Avatar
nateairman
You should just swap your timing cover and turbo onto it and be done with it.
Old Nov 25, 2019 | 07:56 PM
afmedic's Avatar
afmedic
It sounds like hes already stripped the block down. The heads arent on it anymore, and I think the rotating assy has been removed. It would be a full rebuild.
Old Nov 25, 2019 | 08:11 PM
z31freakify's Avatar
z31freakify
IIRC 94.5-95 had that metal plate holding the lifters, also some had 8 bolt plenum versus 10 bolt intake plenums.
Old Nov 25, 2019 | 08:20 PM
afmedic's Avatar
afmedic
the plate holding lifters would be below the head, and hes giving me the intake plenum with it, so I should be good on those I would think
Old Nov 26, 2019 | 04:15 AM
afmedic's Avatar
afmedic
do you know if there is a difference in the 8 and 10 bolt plenum as far as turbo spider alignment? If the plenum opening is in the same spot I'll throw the 8 bolt on the passenger side until I can do a full rebuild
Old Nov 26, 2019 | 10:27 AM
z31freakify
They are both in the same location shouldn't affect spider aligment.
j_rok13
Jan 8, 2008 05:28 AM
f1panel
Jun 22, 2006 09:25 AM
getuted
Nov 19, 2004 06:51 AM
CrazyFordMan
Aug 10, 2003 10:08 PM
Superdave
Jul 6, 2002 10:11 AM
