HELP! Bench Starting 7.3
Old Nov 15, 2019 | 01:39 PM
Gear's Avatar
Gear
I have a 95 7.3, trying to start it on the ground. Truck is long gone, I did however save the throttle pedal assembly from the cab. I have the engine dangling off the engine hoist with the harness draped over it. I have the IDM and PCM both plugged in. The fuses that I have inserted are MAXI fuses 8 (IDM relay) 9 (PCM relay) 12 (Diode) and 22 (PCM). The IDM and PCM relays are intact as well. Fuse 22 receives power from ignition ON so I traced wire to the big bulkhead firewall plug. The pin/wire I put power to that energized fuse 22 on that plug was bigger gauge RED with green stripe. As for grounds, there is a ground coming off either the pcm or idm box and I grounded that. There was two other ground eylets in the mass of wires I hooked up as well. And lastly on that big bulkhead plug there was one pin that was a bit bigger gauge and black that I decided to ground as well and doing so I could hear the IDM click. So with everything hooked up I have power going thru all fuses and both relays sending power out. I cant find a schematic anywhere for that bulkhead firewall plug that labels each pin. Can't find EVTM manual online either. I need to hook up the throttle and don't know where to splice into for it. I cranked it with what I have hooked up so far too and dont hear the distant injector firing cackle. A pin out of the bulkhead firewall plug would really help me. Any help is appreciated, thanks everyone.
Old Nov 15, 2019 | 02:18 PM
nateairman's Avatar
nateairman
Was the truck auto or manual?
Old Nov 15, 2019 | 02:24 PM
Gear's Avatar
Gear
Truck was manual. Sorry, I meant to specify that.
Old Nov 15, 2019 | 02:50 PM
nateairman's Avatar
nateairman
Did you save any of the dash? I have heard that the dash is required. I think for the psom and wait to start light.
Old Nov 19, 2019 | 02:11 PM
quesey's Avatar
quesey
You have to make sure ALL of the grounds are hooked up even the ones on the dash
Old Nov 19, 2019 | 03:31 PM
knottyrope's Avatar
knottyrope
Make sure you attach some 4x4s to it so it cant spin around and injure someone
I have seen what a 20 HP 750 CC engine will damage when not mounted to anything during a bench test
Old Nov 20, 2019 | 04:41 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
There's a video of it on the Youtubez...
Flopping around on a cherry picker like a fish on a hook.
dlconley
1997 - 2003 F150
45
May 5, 2025 07:50 PM
Tom
Feb 11, 2021 10:42 PM
lambchops25
1997 - 2003 F150
Jul 31, 2019 03:58 PM
DLee81
Jul 14, 2019 11:14 PM
AnOldDog
N. California Chapter
Dec 8, 2009 09:22 PM
