Creaking while turning/flexing
Old Nov 30, 2019 | 08:35 PM
UsmcParm's Avatar
UsmcParm
Hey y’all,
just bought a 96 F-250 7.3 4x4 with 200k on it from the original owner. He recently installed a 2 inch RSK with the TTB drop brackets and also new bilstein shocks. Seems he retained the original bushings for everything. I plan on doing a Dana 60 swap in the near future. I’ve noticed while driving at low speed, turning or hitting slight bumps, there is a noticeable creak in what seems to be the driver side front leaf. The bushings look old but barely cracked. Also I should note, the leaf springs are angled down behind the u-bolts. They comedown out of the front shackle but angle down into the rear shackle hanger, forming a slight S. He said the creaking was new but I still talked him down from his price when I bought it so I have a little extra budgeted for repairs. Here’s a picture of the leaf spring orientation. New to these OBS trucks so any info will be greatly appreciated. Thanks
Old Dec 1, 2019 | 08:39 AM
farmert's Avatar
farmert
Welcome to the OBS forums UsmcParm! If I'm not mistaken, the trucks that have the TTB front axles came from the factory with a negative arch. I don't have any experience with the RSK, but I don't think it would make any difference with the way the springs arch. On the creaking, as weird as it sounds, check the fender bolts by the hood hinges to see if they are tight. If they are loose you will get creaking/popping in flex turning situations. Nice looking truck by the way.
Old Dec 1, 2019 | 03:36 PM
z31freakify's Avatar
z31freakify
Clean gorgeous truck!
Welcome to FTE!!
Old Dec 2, 2019 | 08:32 AM
knottyrope's Avatar
knottyrope
Do you feel every crack in the road? If yes then maybe they used the F250 springs.
if the busing are urethane, they can squeak like crazy and ivory soap can stop the squeaks
Old Dec 2, 2019 | 03:10 PM
UsmcParm's Avatar
UsmcParm
Thanks, good to know. I did a bit more research and noticed quite a few others with negative arches as well. As bolts, they are tight. Going to try and swap some bushings for newer ones and see what changes I get. Appreciate it!
Old Dec 2, 2019 | 03:11 PM
UsmcParm's Avatar
UsmcParm
Welcome to FTE!!
Thanks! I plan to keep her that way
somethingclever
19
Feb 15, 2019 07:56 PM
Dashriprock1977
Jun 13, 2017 08:44 PM
padlikehel
15
Mar 12, 2016 10:19 PM
themdgx
1983 - 2012 Ranger & B-Series
13
Dec 16, 2012 10:21 AM
frenchslandscape
Feb 15, 2009 05:31 PM
