400 slight rough idle
Old Oct 17, 2005 | 09:15 PM
mljgauss's Avatar
mljgauss
Just installed a rebuilt 400 tough one from an auto parts store. Run motor for the first 30 minutes at 1500 rpm to lube the cam bearings well during break-in-in as recommended by tom's book. I think that number 4 exhaust value may be burnt. Engine misses and rough idle, very small but detectable (small tick like a value). Motor run very strong and mad oil pressure. Changed intake manifold gasket, which had no change. Will do a compression test at the end of the month.
Spec.
1978 F-250 Camper Special 400 CID <O</OHolly 600 Vacuum secondary
Weined Intake Mallory Unilite (LED) Pro Sidewinder wires Daynomax Headers<O</O
Old Oct 18, 2005 | 12:11 AM
Torque1st's Avatar
Torque1st
Posting Legend
Use a vacuum gage to check the valves. There is a link in my home page links section about 2/3 of the way down with instructions on how to read a vacuum gage.
Old Oct 18, 2005 | 03:28 PM
packlet's Avatar
packlet
LEAKY VALVE: needle drops 2-4 points when valve should close. short circuiting individual spark plugs will indicate cylinder in which the valve is defective, when engine idling.
what does he mean by 'short-circuit' the spark plug? same as disconnecting?
would the cyclinder with the valve problem be the one that does NOT change the bouncing vacuum effect?
thanx. Paul.
Old Oct 18, 2005 | 07:39 PM
mljgauss's Avatar
mljgauss
Ive have already checked vacum which is 22 lb with a slight osilation of 2 pounds at idle. Already disconnected plug wires to deterime number 4 cylinder has little change compared to the rest. Number 4 plug is brownish color where the rest look new.
