Leaking intake on 400
Old Nov 2, 2007 | 11:00 AM
bareaneye's Avatar
bareaneye
I have a 400 with a Weiand intake on it. I have replaced the gaskets with those recommended (fel-pro), used silicone instead of the rubber or cork. I have also used the cork. I have torqued per spec. I have allowed the silicone to dry for at least 24 hrs. I have cleaned very well all of the surfaces. IT STILL LEAKS OIL AT THE REAR!!! This happens about 6-12 months later. I am using the black silicone. What gives?????
Old Nov 2, 2007 | 03:30 PM
Colo79Ford's Avatar
Colo79Ford
Is it leaking at the manifold, or at the oil pressure sending unit?? My oil pressure line leaks like crazy sometimes on the back of the block, and i always thought it was the back of the manifold.
Old Nov 2, 2007 | 10:13 PM
roger dowty's Avatar
roger dowty
if it were the intake you would be sucking in air and losing vacuum...i think. At least thats my experience
