cold starting
Old Nov 22, 2005 | 06:12 PM
rodeostar546's Avatar
rodeostar546
Exclamation cold starting
My F250 5.4 doesnt like to stay running when it is cold. It turns over fine, starts fine then dies. it gives symptoms like a choke not working on a carb. If I give it a little gas and hold the idle myself it will stay running and sometimes ramp up by itself, and then it stays running.
Old Nov 22, 2005 | 07:00 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Nov 23, 2005 | 05:00 AM
FortyFords's Avatar
FortyFords
Change the IAC (Idle air control valve).The most common idle problem with triton v8's and v10's. Its the silver canister thing on the back of the throttle body.
Happy Turkey Day
Rich
Old Nov 23, 2005 | 08:17 AM
rodeostar546
thank you, I will try that, and have a great holiday too.
Old Nov 23, 2005 | 08:22 AM
FortyFords's Avatar
FortyFords
If you go up to the superduty forum,there is a sticky at the top of the forum"FAQ's"
open it click on the truck ,go to the engine tranny area go through you will see a picture of where it is located.
Rich
Lance Helmert
Dec 16, 2014 11:26 PM
suzuki_vinson
Dec 11, 2008 06:35 PM
carphead
1997 - 2003 F150
Jul 20, 2008 08:55 AM
gtex
19
Nov 10, 2005 01:01 PM
