Replace timing chain as preventative maintenance?
Old Nov 12, 2005 | 08:23 PM
DS02F250's Avatar
DS02F250
Question Replace timing chain as preventative maintenance?
I have a 2002 F-250 SD 5.4L 2WD with 96K on it. After checking the Owner's Manual, I don't see a recommendation for replacing the timing chain, not even at the 100K mark. Should I consider this at the upcoming 100K service? or is it not necessary? I will do new plugs and wires, along with cleaning the injectors, and will inquire about cleaning out the carbon build-up that naturally occurs. I'm DEFINITELY into "preventative maintenance", so I was just curious if the timing belt something that I should consider replacing at the 100K mark as well?
Thanks,
DS
Old Nov 12, 2005 | 09:28 PM
HD1340's Avatar
HD1340
If it isn't broke don't fix it! I have seen many of fords modular engines with over
300k on them with no problems! The timing chain, unlike a belt, is pressure lubricated
and self adjusting and will most likely last the life of the engine.
Old Nov 13, 2005 | 08:06 AM
alabamabuddog's Avatar
alabamabuddog
I have a 93 F150 that had 200K on it when I puller it down and there was no play in the timing chain. If I had not been doing a complete rebuild I wouldnt have changed the timimg chain. Ford timimg chains are the best!
Old Nov 13, 2005 | 08:35 AM
Beast12's Avatar
Beast12
Thread moved to 5.4L V8 Engine forum.
-Matt
Old Nov 13, 2005 | 05:48 PM
Bliath's Avatar
Bliath
If it is a SOHC 5.4L Engine, there will be two timing chains on the engine, one for each side of the engine, but I am sure that goes without saying. A DOHC would have 4 chains if I am not mistaking. For the Triton engines I must agree that troubling yourself with the timing chains is hopefully unneccessary as long as there is no problem and hopefully there will never be.
Old Nov 13, 2005 | 06:13 PM
DS02F250's Avatar
DS02F250
Thanks, everyone. I'll leave well enough alone. Guess I was just remembering engines of old where they almost certainly broke a timing chain at 100K miles!
Daryl
Old Nov 14, 2005 | 01:44 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
One thing to add to this:
Unlike a timing belt, the chain will start making noise WAY before it breaks.
I think the DOHC has a small chain from one cam to the other, so while there is "4" chains in a DOHC, only 2 are the really long ones.
bareaneye
Modular V8 (4.6L, 5.4L)
Oct 11, 2016 10:40 PM
hoss73ford
Jun 8, 2016 02:02 AM
LosOsos
May 27, 2016 07:35 PM
stewart
Jul 27, 2009 12:14 PM
Chrisj
1983 - 2012 Ranger & B-Series
Feb 16, 2004 03:46 PM
