Engine shuddering under acceleration; code P0171, P0174
Old Sep 30, 2007 | 04:44 PM
HarleyG8r's Avatar
HarleyG8r
'03 Expedition Eddie Bauer, 4.6L V8
My Expedition is running extremely rough at idle and under acceleration. The problem is much better at cruising speed, but still somewhat noticable. Code reader shows codes P0171 and P 0174 (Lean condition, left and right bank). I tried cleaning the MAF, the problem seemed to go away for a quick loop around the block, but the next time I drove it, problem was back. Help!
Old Sep 30, 2007 | 05:13 PM
pops_91710's Avatar
pops_91710
That's cuz the fuel enrichment circuit has turned off by then and you are running lean again. When's the last you changed the fuel filter??
Old Sep 30, 2007 | 08:09 PM
torkum's Avatar
torkum
Check for holes in the PCV hose elbows at both ends.
Old Oct 1, 2007 | 03:08 PM
HarleyG8r's Avatar
HarleyG8r
I assume the fuel filter has never been changed. Truck has 57K miles, bought it with 34K. Dumb question, I know, but what is the PCV hose?
Old Oct 1, 2007 | 06:42 PM
pops_91710's Avatar
pops_91710
Positive Crankcase Ventilation If you want to save yourself a lot of headaches and future problems change out that fuel filter every 25 k
Old Oct 1, 2007 | 07:17 PM
HarleyG8r's Avatar
HarleyG8r
I'll swap the fuel filter tomorrow. How can I identify the PCV hose under the hood?
Old Oct 1, 2007 | 08:40 PM
pops_91710's Avatar
pops_91710
I don't know where it would be on a 4.6. Usually they are located on the valve cover (passenger side) and a hose runs to the air intake before the TB or air cleaner.
I'm pretty sure I am correct on this.
Old Oct 1, 2007 | 08:47 PM
pops_91710's Avatar
pops_91710
Lok at the illustration here. http://autorepair.about.com/library/...s/bl380lib.htm
Old Oct 2, 2007 | 09:53 AM
projectSHO89's Avatar
projectSHO89
You have a massive vacuum leak.
Your problem most likely isn't the PCV valve, it's that the stupid hose elbows on the line to it are crap. The one all the way in the back facing the firewall is the most common one to fail.
FWIW, you're not running lean, you're running rich. Your fuel mileage is probably poorer than normal.
Steve
Old Oct 2, 2007 | 03:29 PM
HarleyG8r's Avatar
HarleyG8r
I found a small vacuum hose on the passenger side of the engine that was knocked off. I put it back on, and cleared the CEL with the programmer. Now the engine doesn't shudder like it did, but still surges while at idle. No CEL, but haven't driven it much. I did notice that there's a (vacuum?) hose that goes from a point above the brake master cylinder to the throttle body, that the top layer flakes off it when you touch it. I can't really tell if it's leaking though. Would a leak here or in some other vacuum hose cause surging? If not, then what? Also, how can you even tell if a hose is leaking?
Old Oct 2, 2007 | 09:32 PM
pops_91710's Avatar
pops_91710
Get a small bottle of propane and put a small torch tip on. Open it then wave it around suspect areas. If the engine speeds up, it's sucking raw air. I learned this trick from a Ford assembly plant emissions trouble shooter.
Project, no one said the PCV valve was leaking, just said it was the hoses for it.I directed him to the valve which would undoubtedly lead him to the hoses.
Old Oct 3, 2007 | 06:53 PM
HarleyG8r's Avatar
HarleyG8r
Found it!
The rubber elbow all the way at the back of the throttle body was rotted, collapsed and had a small hole. I replaced it with a short length of 5/8" marine fuel hose, and the surging went away. I still have a slight "miss" under acceleration, but the truck idles fine now. Thanks for all the tips, probably would have spent a grand at the dealer, but through here, figured it out for almost nothing.
jls8814
Mar 26, 2014 08:53 AM
raviandsonia
1997 - 2003 F150
Oct 15, 2013 10:18 AM
msradio
Jan 22, 2013 08:16 AM
venturas
3.8 & 4.2L V6
Jan 28, 2012 12:50 AM
HotRod32
Apr 11, 2011 06:00 AM
