97 4.6 no power/7mpg and coolant issue
i have a 97 ford expedition with a 4.6 4x4 on 33's about 160k... i just bought it a few weeks ago... i have done a tune up with iridium plugs new wires,,, oil/tranny fluid changed along with filters... egr coolant flush.. and fixed any vacuume lines that looked rotted i changed... i also put 2 cats on it the others where blown out and i cut off the muffler there was toooo much back pressure ... i have a loss of power mostly no torque and no top end power its great off the line but thats it... on top of that my coolant kind of smells like gas im not sure what that means but the oil is clean no water in it... i get like 7mpg if i drive it regular and granny driving i get 10. o yeah when we did the tune up i noticed water on the no4 plug so im assumeing thats why my water smells like exhaust???? please help..
97 no power...
as far as the gears go i think there stock gears ....tires came with the truck like that he didnt mention anything about replacing gears in fact he said that he bought the truck like that all he did was replace tires because the others were worn .... @ 65mph im at or around 2k rpms maybe a lil less
JL
Was it a stock muffler you cut off? I'm curious as to how it had way too much backpressure. The only way it would have too much is if the catalytic converters were clogged up but you addressed that issue. Try putting a freer flowing muffler on it. That and has the truck always run like this or did it start a while after you bought it?
it had a dynamax on it then... so i purchaced a reg. turbo muffler from them and when down the road and it still made the same sound so i purchased 2 cats had them put them on and it was the same took my mechanic for a ride he said that there was to much back pressure so i cut off the muffler and told them to just pipe it in and refund my money for the muffler to fix the gap in the pipe.... so no i do have more power than before but it still has that sound like something is clogged i did cut the pipes in dif places and ran a snake threw them no clogs ...
i think that might be the whole problem with it ..... ive been told by 3 people now that is what it is im not sure if i posted it before but the coolant smells like exhuast fumes,,,,,,
Champdog21
11-03-2008 09:16 AM
optikal illushun
17
02-22-2004 10:02 AM
