Fuel Pump problem!!
Old Jun 16, 2008 | 09:04 PM
mtestagolf's Avatar
mtestagolf
Fuel Pump problem!!
I have a 1987 f-350 dump with a 460. It is carburated, and I have had to replace the fuel pump in the gas tank a couple of times. Am I getting bad pumps or what. I have a couple of questions, I put a volt meter on the hot wire at the pump(red wire) and it reads 9 volts. Should it be 12 volts, or is t here some kind of reducer. Does anyone know the volts that should go back there or is 9 volts right. I got another pump but am nervous on putting this one in. Luckily all I have to do is put the dump body up to get to the tank. Any help would be appreciated thanks Mark
Old Jun 17, 2008 | 08:48 AM
Conanski's Avatar
Conanski
Should be 12v at the pump, you probably have a bad ground.. which is not uncommon on these older trucks due to rust.
