Bug or feature?
Old Jun 17, 2008 | 09:26 AM
JasonI's Avatar
JasonI
Bug or feature?
In my 1989 F250 2wd, auto, when pulling a trailer uphill, my A/C seems to stop. Does it do this on purpose to give the truck all available power or is the truck using all available power and killing the A/C?
Old Jun 17, 2008 | 09:30 AM
jroehl's Avatar
jroehl
It's all about the vacuum. Under hard throttle/load/acceleration, the engine doesn't create much vacuum, so as soon as the pressure comes up in your vacuum reservoir, the blend doors in the dash go to their default position (defrost), so you don't feel air from the mid-level vents.
Jason
Old Jun 17, 2008 | 09:58 AM
Conanski's Avatar
Conanski
This is built into the computer programming, it toggles off the AC clutch at WOT.. which is actually any throttle position above about 4/5th.
Old Jun 17, 2008 | 11:33 AM
JasonI's Avatar
JasonI
Good to know. Thanks!
Old Jun 17, 2008 | 11:45 AM
gweeds's Avatar
gweeds
Can't it also be a vacuum leak though? I mean, the clutch on the AC going out is because of the computer obviously, but going to defrost means a loss of vacuum pressure, no?
Old Jun 17, 2008 | 01:01 PM
Conanski's Avatar
Conanski
Yes.. that points to a vacuum leak.. though the OP made no mention of the air switching to another vent in his case.
Old Jun 17, 2008 | 02:12 PM
JasonI's Avatar
JasonI
Once I get the #$%@# harmonic balancer back on it, I'll verify that it's not just switching vents.
Old Jun 17, 2008 | 02:56 PM
danr1's Avatar
danr1
The wife's explorer does the same thing, towing a camper through the mountains on a trip out west had it happen to us for the first time.
I thought oh great, on vacation hundreds of miles from home out in this heatwave and the air is going to pick now to die?
Long, steep uphill climbs at full throttle or close to it would cancel the A/C and yea I think it did even switch to defrost when it happen. Backing off the throttle a bit once cresting the hills and everything returns to normal. We got some hills here but nothing that long or steep so we never had it happen before that.
Old Jun 17, 2008 | 04:14 PM
EPNCSU2006's Avatar
EPNCSU2006
Not all vehicles have an A/C WOT cutout. That was one thing that I added when I converted to mass air using a Mustang computer. The Mustang computer had the feature, my stock truck computer did not. Even then, it just disengages the compressor -- it doesn't turn off the whole system (i.e. the fan still runs).
Old Jun 17, 2008 | 04:32 PM
frederic's Avatar
frederic
Some Fords turn off the AC compressor when the coolant temp gets too high. All three times my Intercepter overheated the AC compressor cut off while the temp gauge was at it's normal "4 bars" (digital cluster) then within 10 seconds the gauge jumped to "all bars", the knocking starts, the power goes away, then another 10 seconds later the engine shuts down.
Even if you're on the highway doing 75.
Definately the most bone-headed design there is.
The cause of all this? The electric fan was occasionally drawing over it's 50A fuse, and popping it, thus no fan.
