Up-pipes leaking
Old Aug 10, 2009 | 10:34 PM
70T351W's Avatar
70T351W
Up-pipes leaking
OK read a bunch post's on leaking up-pipes which I have. Do I need to drop the tranny to fix this? It may be more work but if it makes it easier I will do it.
Thanks Tony
Old Aug 11, 2009 | 05:47 AM
FARM69's Avatar
FARM69
You don't need to drop the tranny to replace those donuts on the up-pipes. It may make things a little bit easier, but you'd probably spend more time working on the transmission than you would the pipes.
Old Aug 11, 2009 | 06:11 AM
70T351W's Avatar
70T351W
Really seems tight in there. Would leaking up-pipes really cause power lose?
Old Aug 11, 2009 | 08:48 PM
FARM69's Avatar
FARM69
It's going to be tight. I removed the front driveshaft so you can get your elbows in there.
I thought it wasn't possible at first too.. but after I got it figured out it was smooth sailing.
