fpr shim
Aug 12, 2009 | 01:03 PM
fpr shim
he guys where does the bb go, do i put it toward the inside of the spring or the outside where the bolt is? i got 50 psi and wanted to try this see if i can boost it up some.
Aug 12, 2009 | 01:12 PM
Inside of the spring. "bb then spring then bolt"
Aug 12, 2009 | 01:35 PM
Aug 12, 2009 | 01:38 PM
Quote:
Originally Posted by
jleal_21
Check this:
http://rides.webshots.com/photo/1344...67175480afBLqR
Aug 12, 2009 | 06:27 PM
Well jstu to wonder I assume you can do this while leaving the FPR in place and just taking the bolt off? Cause I want to do this but I don't want to take the FPR off.
Aug 12, 2009 | 06:45 PM
yea you can leave the fpr in. I used the spring to "hook" the triangle and pull it out. Good luck
Aug 12, 2009 | 06:47 PM
Oh and make sure you don't drop anything in the valley. It is a pita to go retrieve anything there.
Aug 12, 2009 | 09:59 PM
thanks for the help guys. fuel pressure on my truck went up about 15 psi. had about 50 and got to 65. truck does seem to run a little better.
Aug 13, 2009 | 07:56 AM
Yeah, when I did mine I went from 40 psi to 65 psi. Runs better now.
Aug 25, 2009 | 04:54 PM
it was a 3/16 bb "ball bearing" right
Aug 25, 2009 | 08:15 PM
I just used a BB for a bb gun... worked great!
Aug 25, 2009 | 08:41 PM
Brown Falcon
X2 what he said. And the recommended 3/16 BB could fit in the hole in my case and the BB gun worked fine.
smallello
Feb 4, 2014 09:37 AM
omni
Dec 28, 2007 04:01 PM
1991redneckf150
Feb 12, 2007 01:59 PM
BullWapiti
Oct 27, 2005 06:59 PM
c_rossman
Apr 3, 2004 05:42 PM
73 ,
73l ,
95 ,
f150 ,
fbr ,
ford ,
fpr ,
fuel ,
mod ,
powerstroke ,
pressure ,
regulator ,
shim
