2004 PSD files when warm
Old Jun 16, 2020 | 09:50 PM
Frustrated in mt's Avatar
Frustrated in mt
I have a 2004 f350 6.0. right now I am having an issue where it starts and runs until it gets just above the c on the temp gauge and it dies. It will not restart till it cools down. Ecm, map sensor, ficm have all been changed. Now here is the kicker. My son has an 06 f350 6.0 his computer will run just fine it's just for an automatic and mine is a standard. Help
Old Jun 17, 2020 | 08:59 AM
redford's Avatar
redford
FTE Leadership Emeritus
I moved your thread to 6.0L engine forum and renamed thread with a descriptive title. This should speed up getting you good advice and valuable suggestions.
Good luck with your diagnosis and repairs.
Old Jun 17, 2020 | 10:12 AM
xcrsp440's Avatar
xcrsp440
You will need to get monitoring tools to see what happens as the engine dies.
A mobile app like Forscan and an adapter for the obd port will help. Pretty cheap too, under $40 for the pair.
Likely you are loosing oil pressure to the injectors as the oil heats up and thins out. So probably have a leak in a seal or fitting somewhere.
powerstrokeken6.0
Apr 19, 2014 07:18 PM
Chadyent
Aug 16, 2013 06:17 AM
teddyinastroker
Oct 31, 2012 09:51 AM
srs1111
Jun 9, 2012 01:16 PM
