Kinda having a hard time find any kind of instructions about how to install EGR delete. Anybody got a video or a document with how to do the install? It seems like you gotta know somebody that knows somebody to get these instructions..
You could probally make metrics around slot of the claimed benefits
Unfiltered EGR Systems can lead to:
Clogged EGR coolers
Clogged EGR valves
Particulate matter buildup in intakes
Particulate matter buildup on grid heaters
Particulate matter buildup on intake valves
Particulate matter buildup on top of piston rings
Excessive particulate matter introduced in your engine oil
FASS EGR Filter System benefits:
Filters out 85% of particulate matter from the EGR stream
Extends the life of the EGR cooler and EGR valve
Reduced particulate matter build-up on grid heaters
Reduced particulate matter build-up on intake valves
Reduced particulate matter build-up inside intakes—allowing proper airflow
Reduced particulate matter build-up piston rings which minimizes the possibility of broken rings and engine failure
Reduced soot content in engine oil (verified by oil sample analysis)
FASS EGR Filter System specs:
409 stainless steel body
85% filtration of particulate matter
Self-cleaning, auto regeneration, low maintenance!
Specifically designed for use in the EGR stream of diesel engines
