adventure and update post...
Old Jan 8, 2013 | 11:34 PM
  #541
ZakMay09's Avatar
ZakMay09
Thanks for the heads up before I went all buck wild! haha I hope you and your family are doing well brother. Can't wait to see the next update!
Old Jan 8, 2013 | 11:48 PM
  #542
Redneckfordf2502002's Avatar
Redneckfordf2502002
I already have a build thread for our expedition and other trucks Russ you should probably check it out when you get the chance.
Trav
Old Jan 31, 2013 | 12:29 AM
  #543
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
will do!
so tonight i changed the oil and attempted to fix my A4wd problem. i pulled the shift motor so i could get to the front HALL sensor in the t-case. pulled it out an cleaned it off. only had a small amount of metal dust on it. went ahead and cleaned the rear one also again. disconnected the battery and then tried it. NOPE! still get a flashing A4wd light. 4hi and 4low work perfectly. so i suppose my next step is to change both HALL sensors in the t-case and work from there. weird it just all of a sudden died this fall.
sitting at 87,707 after i went and got gas tonight.
Old Jan 31, 2013 | 02:24 PM
  #544
Redneckfordf2502002
Looking great Russ. I know you like showing off in other forums so check out this thread I started: https://www.ford-trucks.com/forums/1...l#post12780318
Trav
Old Jan 31, 2013 | 02:38 PM
  #545
Skip1970's Avatar
Skip1970
how you like that mobile one?
Old Jan 31, 2013 | 02:48 PM
  #546
Redneckfordf2502002
(personal usage not talking for Russ or trying to hijack his thread) I have used mobile one on the 97 Expedition of ours and personally love it. ours is about due for an oil change soon and the truck hasn't lost a drop even and ours is a high mileage truck. I am very satisfied with it if they don't have Valvoline next time I get oil for the oil changes (I use valvoline usually along with Castrol GTX) I will use the Mobile one again.
Trav
Old Jan 31, 2013 | 04:22 PM
  #547
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i've been using mobile 1 synthetic in my all trucks ever since i started driving. i've differed a few times but always go back. it doesnt seem to get nearly as dirty over the same mileage as others i have tried and everyone says its great so i just stick with it.
my Expy has the the typical oil seepage on the oil filter remote mount. seems to be very common on the trucks that have them. but i think over 5-7k miles i loose maybe a quart give or take alittle bit. its not much.
Old Feb 1, 2013 | 02:24 AM
  #548
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i got a free trailer today, needs some work. thinking new paint, tires, lights, tarp, pack the wheel bearings and put some fenders on it. very well built!
Old Feb 1, 2013 | 02:58 AM
  #549
Redneckfordf2502002
Russ it looks great you are lucky when I put a trailer on our expy the rear end is completely lowered (it needs new shock absorbers I believe).
Trav
Old Feb 14, 2013 | 10:20 PM
  #550
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
my buddys 98 which is almost identical to mine option wise sags in the rear, mine sits about 1.5" higher then the front idk why.
so tonight i replaced the running board lights and door lights, plate lights with LEDs
before
after
also ordered and installed discontinued silver star turn signal bulbs. i love the blueish look when they are off.
Old Feb 15, 2013 | 12:02 AM
  #551
Skip1970's Avatar
Skip1970
Reminds me what burned put bulbs look like
Old Mar 13, 2013 | 01:02 AM
  #552
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
rolled 88K miles the other day, she keeps on truckin!
got alittle snow on her the other day.
we got a close family friend who just moved up here a 2002 expy so i had to get pics together haha
Old Mar 30, 2013 | 03:38 AM
  #553
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
some random shots from the last few weeks. i need to get pics of the LED interior lights i put in. about 20x brighter then stock and thats awesome because with 2 dome lights it gets dark in the big expy!
we had a good snow storm the other day, 12-20" depending on what part of town you were in. i'll give you a slight time lapse of the event.
the night before, we had 6" that day and i had cleared the expy off. this was 10pm
the next night at 11pm
is this considered expy abuse? lol
pic today of my expy, dads explorer and my explorer.
Old Mar 30, 2013 | 01:59 PM
  #554
alloro's Avatar
alloro
Your pictures never cease to amaze me.
Old Mar 30, 2013 | 05:20 PM
  #555
TheACN's Avatar
TheACN
Love your license plate, tells so much
Could you tell me which brand and model jacks stands do you use? Clearance looks perfectly nice.
