1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
more VIN numbers
  #316
Old 09-16-2014, 07:19 PM
garyall's Avatar
garyall
garyall is offline
can somebody help me with this vin E38ahba2110
  #317
Old 09-16-2014, 09:02 PM
TexasTurkey's Avatar
TexasTurkey
TexasTurkey is offline
Could you tell me what my transmission is?--I assume it's the 4 speed auto
1FTYR10C9YPA37086
it's a 2000 Ranger 2.5
Thank You in advance
  #318
Old 09-17-2014, 12:05 PM
TA455HO's Avatar
TA455HO
TA455HO is offline
1FTYR10C9YPA37086
Too funny. The VIN you typed in became a link to the VIN decoder with your info. Try just clicking on your own VIN link. Looks accurate to me, but ??
Or this link might also work.
VIN Decoder - Ford Truck Enthusiasts Forums
You posted your question in the 1961-1963 Ford Unibody section.
  #319
Old 09-30-2014, 03:54 PM
kjvforme's Avatar
kjvforme
kjvforme is offline
Originally Posted by sheldon1
Thanks, when I try to go to mercurypickups.com I just get a unable to load page. I'm wondering if it is shut down?
Ok I curious what year is it, and is it a Unibody?
  #320
Old 09-30-2014, 04:15 PM
kjvforme's Avatar
kjvforme
kjvforme is offline
Would one of you be willing to tell me what you can about my "new" purchase please?
Thanks
Sheldon
66595A
66595 =Serial number
A= load rating
4662522-L
4= Ford V8
66 =Unibody
25= F250
22= 122 In WB
L= Left Hand Drive
Trim 202 sorry nothing on that one, 1 might be Standard cab, 2 Delux cab
1TT= Sultana Turquiose
Axle Ration 4.56:1
Series F-F250
GVW 5400 Lbs
R= engine 292?
4 Spd manual trans
Most of this information is hit and miss, this is what I have managed to collect so far. Heck have more questions than answers, what engine?
  #321
Old 10-01-2014, 02:04 AM
sheldon1's Avatar
sheldon1
sheldon1 is offline
Thanks, spot on.
And it is indeed the 292. The door has custom cab written on it. Perhaps that is the trim code?
Originally Posted by kjvforme
66595A
A= load rating
4662522-L
4= Ford V8
66 =Unibody
25= F250
22= 122 In WB
L= Left Hand Drive
Axle Ration 4.56:1
Series F-F250
GVW 5400 Lbs
R= engine 292?
4 Spd manual trans
  #322
Old 10-01-2014, 01:13 PM
kjvforme's Avatar
kjvforme
kjvforme is offline
Still curious what year is it?
  #323
Old 10-03-2014, 09:10 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Could you tell me what my transmission is? I assume it's the 4 speed auto
1FTYR10C9YPA37086 it's a 2000 Ranger 2.5
The TRANS code is not within the VIN of any FoMoCo vehicle.
Beginning 1980, TRANS code printed on the Certification Label which is glued on. Prior years, it was stamped on the Rating or Warranty Plate.
  #324
Old 10-03-2014, 09:19 AM
NumberDummy
Originally Posted by garyall
can somebody help me with this vin E38AHBA2110
You posted this question in the wrong forum, this is for 1961/63 Ford F100/250 Uni pickups.
Ask further questions in the 1968/2013 Full Sized Van (Econoline) forum.
E38 = E350 Cut-Away.
A = 460 4V
H = Lorain OH Assembly Plant.
BA2110 = 1978.
Cut-Away: FoMoCo cuts the Econoline van body off behind the front seats so that aftermarket body makers can install a box van, people mover, ambulance and etc bodies.
Cut-Away also used for Class C motor home bodies.
Line 3: E250/350 Cut Away Cab =
  #325
Old 10-03-2014, 01:13 PM
sheldon1's Avatar
sheldon1
sheldon1 is offline
1961
1961,
well at least according to the registration.
  #326
Old 10-04-2014, 10:31 AM
kjvforme's Avatar
kjvforme
kjvforme is offline
Thanks for the reply it hard to figure that one out. I haven't seem a production numbers by years yet for the Canadian Fords or Mercurys.
  #327
Old 10-13-2014, 02:23 PM
Tboquet07's Avatar
Tboquet07
Tboquet07 is offline
Can I get help with the dso code#1096 .the truck vin is f10jk155713 the truck is a 1961 f100 unibody. Thanks
  #328
Old 10-14-2014, 02:47 AM
NumberDummy
Originally Posted by Tboquet07
Can I get help with the DSO code#1096? VIN: F10JK155713 .. the truck is a 1961 F100 unibody.
Welcome to FTE
F10 = F100 2WD
J = 223 1V I-6.
K = Kansas City MO Assembly Plant.
155713 = 1961, assembled March 1961.
1096 = Domestic Special Order number, your truck was special ordered by the original purchaser, not "bought off the lot."
Look on the Warranty Plate, is there a COLOR code, or is it blank?
  #329
Old 10-14-2014, 05:04 AM
Tboquet07's Avatar
Tboquet07
Th color code is m .thanks for the info I bought the truck from the second owner. It also has the 3 on the tree and looks like it had factory air and no radio holes .
  #330
Old 10-14-2014, 06:01 AM
NumberDummy
Factory installed A/C was not available for these trucks, it was only available dealer installed.*
Domestic Special Order: 4 digit DSO:
Some type of special equipment was installed on the truck after it left the assembly line that was not an RPO (Regular Production Order).
Or if the truck was ordered with a non standard color, there would be no COLOR code stamped on the Warranty Plate.
Special equipment could be a 4WD conversion. Or some sort of "back of cab" equipment like a Utility Bed, for an example. But obviously this wouldn't apply to a Uni.
*It could also be the A/C that this truck has.
The problem is, there is no way to discover what type of special equipment was installed, because the IDIOTS at FoMoCo THREW AWAY all the records decades ago!
Quick Reply: more VIN numbers
