December Chat Thread
Old Dec 14, 2009 | 12:13 AM
  #181
TheKirbyMan's Avatar
TheKirbyMan
Ya'll want tight fit? Change a Jeep Cherokee starter, lol. That was....fun. I used a cheater tool, a socket with a five-pointed base (like a nut) and a box-end wrench. Took a while to get it done since I had only a little room to work, but I got it done and everything worked perfectly.
By far, the tightest fit I've had to work with was when I replaced the exhaust donut on the Cherokee. Stuck bolts and very limited working space made for a rough evening and lots of grumbling. lol
On a more positive note, I changed the spark plugs last night on my truck. Went from Bosch SuperPlus to Motorcraft. Only took me about an hour and I didn't break ANY! I noticed a decent improvement in the way the engine runs now, but it still needs that rebuilt carb. It's still running rich enough to nearly gag me from across my front yard.
Ya'll don't know how good it made me feel to hear it running that good again. I was even able to put it in gear without it shaking and dying.
Old Dec 14, 2009 | 12:28 AM
  #182
bill11012's Avatar
bill11012
Modular motor junkie
Cool Kirby, I have always had good luck with motor craft plugs.
Need to get a new carb on my 460 too.
I have rebuilt it twice and it still leaks fuel inside and out,I just need to spend $350 on a whole new carb....
I changed the head gasket on my tractor, and took a nice 50 miles trip on some back roads in my old cop car.
I had a pretty good day.
Old Dec 14, 2009 | 02:54 PM
  #183
TheKirbyMan
Sounds like a good day indeed.
Someday I'll get a new carb for mine too...I'm thinking about a Holley Truck Avenger. It's like 470CFM and has a bunch of interesting off-road features. Check out the vent tube design, for example.
Old Dec 14, 2009 | 03:31 PM
  #184
bill11012's Avatar
bill11012
Sounds like a good carb, but do you lose any economy or performance in trade for the off road features?
Old Dec 14, 2009 | 06:37 PM
  #185
TheKirbyMan
I'm not sure. If I had to guess, I'd say it's optimized to make power at low and mid range, so it's probably not gonna do too well on a screamer motor. As far as economy, I don't guess it'd affect it too much more than a regular four-barrel (I read in a Four Wheeler mini-article about it that it got about 2mpg less than the spreadbore carb it replaced)...most of the special features seem to be geared toward fuel control as opposed to outright performance.
Old Dec 14, 2009 | 06:43 PM
  #186
bill11012's Avatar
bill11012
Sounds good to me, how much is it?
Old Dec 14, 2009 | 06:47 PM
  #187
TheKirbyMan
Seems to be in the $300-$400 range. Probably want to factor in the price of a four-barrel manifold if you were swapping out a two-barrel.
I can't tell by the picture if it'd work with a factory air cleaner. It looks like that vent tube might be a little too tall.
Old Dec 14, 2009 | 07:09 PM
  #188
Jmeyer1990's Avatar
Jmeyer1990
A Hammer can take care of that for ya.
Old Dec 14, 2009 | 07:30 PM
  #189
6fifty_f1fifty's Avatar
6fifty_f1fifty
I didn't think it was possible to hurt the fuel economy of a 460... I rebuilt mine (4180 carb on a 460) as well, I don't think it leaks, but I do know it isn't adjusted right. it idles high no matter what I do to the idle screw or idle mixture screws.
Old Dec 14, 2009 | 08:14 PM
  #190
86bigred's Avatar
86bigred
I've got an edelbrock 650 on my 460.I got good fuel econmy but no power,till I found the secondary's weren't opening.fixed that with an adapter plate,got my power back,but fuel econmy went back to 10 mpg.
Old Dec 14, 2009 | 08:19 PM
  #191
greyghost85's Avatar
greyghost85
stay outta dem secondaries.....lol
Old Dec 14, 2009 | 08:59 PM
  #192
bill11012's Avatar
bill11012
hahaha
Mine open too early, I cant go over 30 with out getting into them. I need to set it so I have 3/4 before they kick in.
I can get 12 with out them, 5 with them.
They dump so much raw fuel in....
I have a 4180 and I don't like it, Mine wont adjust right either.
10 MPG? I would be happy if I could get that. Thats 2X mine.
What did you get before you fixed the secondarys?
Old Dec 14, 2009 | 09:16 PM
  #193
Jmeyer1990's Avatar
Jmeyer1990
Hey, did they get rid of the 1 hour limit on editing posts?
I seem to be able to edit things that I posted a few days ago...
Old Dec 14, 2009 | 09:25 PM
  #194
6fifty_f1fifty
problem with the 4180 is the evap connections on both bowls, I switched to an edelbrock 1406, but the power was non existent and she constantly backfired under load, Edelbrock told me to use different metering rods and pink springs, that helped the backfiring but she sure had no guts. Back to the evap tubes, I thought maybe I could rip out the whole fuel vapor return system, but I didn't want to screw up the whole system. The whole emissions crud on this beast is weird, she has an air pump to inject fresh o2 for a catalytic system, but is labeled as a non-catalytic system with no cat...
Old Dec 14, 2009 | 09:35 PM
  #195
bill11012's Avatar
bill11012
Your right, how did you find that?lol
You should remove all the emissions stuff.
Makes it run much better.
