December Chat Thread
Old Dec 12, 2009 | 12:02 PM
  #151
newrider3's Avatar
newrider3
Yeah, something tells me the choke doesn't work. With the engine off, it is open a crack. With it running and kicked down to a normal idle, it is only a sliver more open. And when it is hot and idling weird, it is still mostly closed. If I open it by hand, it starts to idle a bit higher, but a little rougher.
Old Dec 12, 2009 | 12:54 PM
  #152
doug1222556's Avatar
doug1222556
On mine the wire runs to the back of the alternator. Have you tried setting it leaner? If you were getting voltage to it and it isn't opening it may be set too rich. Try going leaner with the engine cold until it just opens, then back richer just enough to close it. If it doesn't open pretty quickly then, you have some other issues with it,
Old Dec 12, 2009 | 01:00 PM
  #153
doug1222556
BTW- I don't know what's so hard about locating this: AutoZone.com | Tubing Repair Kit.
I remember when you had to know something to work at an Auto Supply.
Old Dec 12, 2009 | 01:51 PM
  #154
newrider3's Avatar
newrider3
I don't know, we sat there and searched every term we could think of on the catalog computer, and I looked in the whole store.
Old Dec 12, 2009 | 02:35 PM
  #155
doug1222556
You might still want to pick one of those up. It will fix it back to original working order. If you look, you'll see it even includes the woven heat shielding sleeve, which in this case is to keep heat in. It's a small tube with a long way to go, without it air temp will vary the amount of heat delivered to the choke.
Old Dec 12, 2009 | 03:55 PM
  #156
newrider3's Avatar
newrider3
I put the old insulation back on the new tube. I went out and hit the choke wire with a test light while running and it seems the wire is dead. Also, I took a pic of the choke showing how far it opens whilst idling. I was able to get the choke to hold itself fully open by pushing it there once, but when I hit the throttle it went back to the half closed position. It wouldn't hold itself full open but that one time.
Old Dec 12, 2009 | 04:23 PM
  #157
doug1222556
AH HA- There ya go. That wire should have constant voltage when the engine is running. That's why mine is on the back of the alt. Trace that wire down and check the connectors on both ends. Look especially close at where the connectors have insulation on them. They have a nasty habit of breaking there, giving intermittent voltage that will drive you up the wall trying to locate. Wiggle the wire around at the connector, if it's broken it will bend real easy.
If you don't find any problems there, replace the whole wire. UMMN- well, you should probably check for voltage at the source end first. If you have voltage there and not at the choke.......
Old Dec 12, 2009 | 05:37 PM
  #158
newrider3's Avatar
newrider3
Hmm. I went and tested the wire again, and it was hot. I reconnected it to the carb, and now apparently it is working. Ran fine, and when I got home the choke was open and it idled alright.
Old Dec 12, 2009 | 10:33 PM
  #159
Jmeyer1990's Avatar
Jmeyer1990
I put my baby to good use today.
Helped a friend tow his truck, and pulled a honda out of a snow mound haha
Old Dec 12, 2009 | 10:39 PM
  #160
bill11012's Avatar
bill11012
Modular motor junkie
Your friends truck break down or get stuck?
Old Dec 12, 2009 | 11:32 PM
  #161
Jmeyer1990's Avatar
Jmeyer1990
His f150 broke down, wouldn't start because the starter chewed away at the flywheel wearing most of the teeth down.
It should not take 3 hours to get a damn starter out of a truck haha
Old Dec 13, 2009 | 06:42 AM
  #162
greyghost85's Avatar
greyghost85
did the starter get the flywheel, or the flywheel get the starter? going thru the same thing, myself
Old Dec 13, 2009 | 10:57 AM
  #163
Jmeyer1990's Avatar
Jmeyer1990
In his case, the starter got the flywheel.
He loaned the truck to someone, who for some reason over cranked the truck (i.e turned the key to cranking position when already running) and destroyed a section of the flywheel, and at the same time wore the starter bendix down.
And over time, it got worn down to the point where he couldn't start the truck at all.
Old Dec 13, 2009 | 10:58 AM
  #164
6fifty_f1fifty's Avatar
6fifty_f1fifty
what year is his 150? it takes about two-three minutes to get one out of ours...
Old Dec 13, 2009 | 11:01 AM
  #165
doug1222556
A flywheel? This I gotta see!
