December Chat Thread
Old Dec 10, 2009 | 07:39 PM
  #136
newrider3's Avatar
newrider3
It was -18* F yesterday morning here.
Old Dec 10, 2009 | 07:40 PM
  #137
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by Jmeyer1990
there, you should finally be able to see it
Haha, we won and thats all thats counts.
Really though, He ripped UTs offense apart EVERY play.
I was not sure if they could win for part of the game.
Old Dec 10, 2009 | 07:44 PM
  #138
86bigred's Avatar
86bigred
i've worked in -40* f/c in the oil fields up here in the great white north,and even had to replace a starter in those temps as well.
Old Dec 10, 2009 | 07:53 PM
  #139
bill11012's Avatar
bill11012
Wow, thats a little cold for me.
Old Dec 10, 2009 | 07:55 PM
  #140
86bigred's Avatar
86bigred
me too.LOL
Old Dec 10, 2009 | 07:59 PM
  #141
Jmeyer1990's Avatar
Jmeyer1990
He was like that the entire season, which is why we (husker nation) are hoping he gets the heisman this weekend.
Old Dec 10, 2009 | 08:34 PM
  #142
doug1222556's Avatar
doug1222556
Originally Posted by 86bigred
me too.LOL
Are you kidding me- I got to go get my thermal coveralls on just to watch a hunting show in Alaska or one of those Everest expeditions.
Old Dec 10, 2009 | 08:37 PM
  #143
greyghost85's Avatar
greyghost85
i was in -45 degrees F in Alaska. Truck wouldn't start and had batt jumper cables stored behind my seat. when i straightened them out, they snapped!
Old Dec 10, 2009 | 10:15 PM
  #144
bill11012's Avatar
bill11012
So cold copper snapped? WOW.
Old Dec 10, 2009 | 10:18 PM
  #145
bill11012's Avatar
bill11012
I would not be surprised if He did.
Old Dec 10, 2009 | 10:42 PM
  #146
TheKirbyMan's Avatar
TheKirbyMan
It was in the 20s this morning. I was going to crank my truck and see if it would run in this cold without the choke working, but the front tire has a slow leak and it's flat, so I couldn't have backed it up so as not to fill my room with exhaust. lol
If all goes as planned, tomorrow I'm hoping to pick up new spark plugs, plug wires, and a distributor cap for it tomorrow. If a transmission pan gasket isn't too high I might pick one up too.
Old Dec 10, 2009 | 11:24 PM
  #147
Jmeyer1990's Avatar
Jmeyer1990
The gasket for my truck, (c6) was only 11 bucks, but it came with a new filter also, so it's a good deal!
EDIT!: It's only 7.99, it was 11.99 for my Topaz, not the F250.
Old Dec 11, 2009 | 01:25 PM
  #148
TheKirbyMan
That's about the price NAPA quoted me for one for my truck. Came with a filter too, I think.
Well I'm gonna grab some lunch then head to work. But before I leave I'm going to dump the little carb parts into the cleaner so they can soak while I'm at work.
Old Dec 11, 2009 | 05:43 PM
  #149
newrider3's Avatar
newrider3
So I rigged up a new choke heat riser out of some hose and a piece of flared brake line, the parts shop didn't know wtf I needed, let alone have a universal kit. Anyway, the choke and idle problem is still there. Also, this morning it was sputtering all the way to school. On the way home it ran better, but surged a bit whenever I tried to hold a constant speed (fine accelerating and coasting). I have no idea where to start, besides that my truck doesn't like cold.
Old Dec 12, 2009 | 02:59 AM
  #150
TheKirbyMan
You could try what I did...loosen the three screws that hold the choke housing down, and rotate the housing til the choke plate is wide open. You'll have to manually raise the idle to warm it up (I bring mine to 1200rpm for about a minute, then let it go down to 800-1000 if it can hold that for a minute, then back up to 1200, then back down to 800-1000, and I do this for about 5 minutes), but you won't have any issues with loading up or running rich due to the choke being closed.
You could also try pulling your carb off and spraying it down with some B12 and get whatever gunk out of it, then see if that helps.
These old Fords are cold-natured indeed. But once you get 'em warmed up, you're set.
Oh and I picked up a set of Accell Super Stock 8mm plug wires today along with a set of Motorcraft spark plugs. Turns out the plug wires are universal fit, so I think I'll have to cut them to the proper lengths and crimp on the distributor clips and put the boots on. The spark plug ends are already installed.
I like that they're red boots with yellow covering, it makes it look like I'm packing some kind of hot engine lol
