Sponsored by: Real Truck
Gas vs PSD
Old Jul 1, 2009 | 01:53 PM
  #166
Ford79's Avatar
Ford79
Yeah, apples to apples
Why did the diesel climb the hill almost 5 seconds faster than the gas, at least on the 15% grade.
Speed was real close at the top of the "huge" 250 meter course too.
The 7% grade is almost identicle.
The F350 weighs 1170 pounds more too.
And again in the 1/4 mile. Unloaded is very close and loaded is won by the diesel by 1.5 seconds
Old Jul 1, 2009 | 01:55 PM
  #167
Johnny Langton's Avatar
Johnny Langton
Originally Posted by miller_feed
Heck, my truck comes with 250 HP from the factory.
Yeah,and it's also limited on how much boost it receives from the turbo when it's stock.
JL
Old Jul 1, 2009 | 01:58 PM
  #168
CampSpringsJohn's Avatar
CampSpringsJohn
Hey Rick, you could pull the DP and put your Edge programmer back in to help even up the trucks!
Old Jul 1, 2009 | 02:00 PM
  #169
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
JL
Right now, I would think we have right at the same HP.
Old Jul 1, 2009 | 02:02 PM
  #170
mudmaker's Avatar
mudmaker
you know looking at those charts again it is interesting they used mph instead of time on the test to keep the lines closer. Just typical playing with numbers to generate interest.
They might top out at the same speed, but diesel got there a lot faster.
Old Jul 1, 2009 | 02:07 PM
  #171
miller_feed
. John, now, you know my truck would be so peed at me if I did something like that.
Old Jul 1, 2009 | 02:10 PM
  #172
Johnny Langton
Are you blind? They have mph and time both listed on the charts.
And they did not top out at the same speed-the 6.8L is actually moving at a higher rate of speed. It was also still gaining speed where the 6.4L was gaining very little.
Over a 100 meter distance(150-250meters) the 6.8L gained 9mph in a 9 second timeframe. The 6.4L gained 1mph in the same timeframe and distance.
JL
Old Jul 1, 2009 | 02:23 PM
  #173
miller_feed
JL
I think what he was meaning is, if you were standing at the top of the hill, the 6.4 would have toped the hill, then 5 seconds later the 6.8 would pass.
Old Jul 1, 2009 | 02:30 PM
  #174
Ford79's Avatar
Ford79
JL
Uhhh, not exactly. The V10 gained just under 4mph over the 100 meters(150-250) in just over 9 seconds. The diesel only gained about 1mph and covered the same distance in just over 8 seconds.
Either way, the diesel made the same trip(250 meters) almost 5 seconds faster, regardless of speed.
Yeah, essentially, that's what the chart shows.
Last time I checked 26.75 was faster than 31.53.
Old Jul 1, 2009 | 02:38 PM
  #175
cpdorroh's Avatar
cpdorroh
I figured we'd be running low on beer, so I brought some more. Help yourselves. This has gotten pretty good.
Old Jul 1, 2009 | 02:40 PM
  #176
mudmaker's Avatar
mudmaker
It will if the DOT ever pulls you over and puts you on a scale. GVWR, front and rear GAWRs, and the GCWR are all very important to those guys.
JL
GVWR is the only thing that matters. You cant know the GCVWR without the information from the trailer you are towing. So if two pickups both with the same gvwr and trailers with the same gvwr in tow will have the same GCVWR no matter what rear end they have.
Old Jul 1, 2009 | 02:41 PM
  #177
Johnny Langton
Yep-I rear the same chart twice-it's so small up there in the quote that it's hard to read.
Either way,I'm not disputing the elapased times at all-I never have. But,the 6.8L was still gaining speed at the end of 250 meters where the diesel was barely gaining anything. You commented earlier about the "huge" 250 meter test-would you like to have seen 500 meters? How about 1000?.
JL
Old Jul 1, 2009 | 02:52 PM
  #178
miller_feed
JL
Are you BLIND?. . It shows it very clearly in the first chart.
Old Jul 1, 2009 | 03:13 PM
  #179
jdadamsjr's Avatar
jdadamsjr
Smile
I guess we won't have any takers.....
just like the last 4 or 5 times we went through this !
all we have is "expurt witnesses" and "statustics"(sic) ???keyboard jockies ?????
Saddle up !!!!!!!!!!!!!!!!! let's go.... it'll be fun !!!!!!!!!!!!!
I'll post the results here !!! - name the contest
If'n I lose, big deal, if'n I win,
bet will be like the media covering another lefty not paying his taxes and spending ours !!! quiet
Old Jul 1, 2009 | 03:14 PM
  #180
superduty4x4's Avatar
superduty4x4
Thanks for coming to the rescue!
