Sponsored by: Real Truck
Gas vs PSD
Old Jul 6, 2009 | 11:35 AM
  #271
krewat's Avatar
krewat
FTE Leadership Emeritus
Mmm, mmm, diesel and Big Mac sauce.
Old Jul 6, 2009 | 01:45 PM
  #272
bigrigfixer's Avatar
bigrigfixer
The Pacifier
Originally Posted by Pinky Demon
Do you understand what a joke is?
Yeah, but apparently it was lost on you. Try not to worry about it too much.
Old Jul 6, 2009 | 01:48 PM
  #273
Angrywasp's Avatar
Angrywasp
Arby's is better and so are their fries.
Old Jul 6, 2009 | 02:06 PM
  #274
krewat's Avatar
krewat
So besides padding your post count, can anyone add anything to this thread or what?
Old Jul 6, 2009 | 02:20 PM
  #275
Angrywasp's Avatar
Angrywasp
Doubt it but I'm just here for the beer.
Old Jul 6, 2009 | 02:22 PM
  #276
brian42's Avatar
brian42
Veteran: Navy
I'll even spot you the '08 V10 powerplant numbers:
HP: 362@3250RPM
Tq: 457@4750RPM
Now turn the way-back machine to 6 years ago and the last of the 7.3L's:
HP: 250@2800RPM
Tq: 525@1600RPM
If you want a hot rod, then the V10 is the way to go. If you're old (like me) then it's all about the grunt, and that's why I've got the 7.3L.
Even though the V10 delivers only 68lb-ft less torque (you're talking 650lb-ft out of the new diesels), I'm getting all my stump pulling power to the ground at 1600RPM (not much off idle), throw in 17 mpg and I'm sold!
If you don't actually need the truck, then it comes down to personal preference. Unfortunately it's hard to get an unbiased opinion. It's like going to your first school dance with all of the boys on one side and all of the girls on the other and nobody talks to each other. When it comes down to it, a Super Duty is a Super Duty. I just happen to like pulling into a fuel station and only having two nozzles I can use (and usually have to wait behind some woman who can't figure out how to fill up her Yukon), being able to smell my engine while I'm driving it and having people turn their heads as I drive down the street because they think the garbage truck is coming.
Not to mention that with the second alternator I have 220 amps of service available.
Old Jul 6, 2009 | 03:42 PM
  #277
Johnny Langton's Avatar
Johnny Langton
[quote=brian42;7686262
[/quote]
Forced induction has a funny way of doing that.
JL
Old Jul 6, 2009 | 03:50 PM
  #278
mudmaker's Avatar
mudmaker
JL
So you must be saying because the 7.3 has a turbo it makes it a superior powerplant!
Old Jul 6, 2009 | 04:29 PM
  #279
Ace!'s Avatar
Ace!
HP: 362@3250RPM
Tq: 457@4750RPM
HP: 250@2800RPM
Tq: 525@1600RPM
I've never really understood why people are afraid of the RPMs. Why is it better to top out at 1600 RPM? What if you're pulling a trailer through the mountain passes and your trying to pick up speed? If the 7.3L you're talking about reaches 1600 RPM it then drops off, right? So, say you are driving over a pass and want to pass a vehicle, wouldn't it be better to have peak numbers at a higher RPM? Are 7.3L only good for pulling stumps? What about once you've pulled the stump and now you want to take it somewhere? So, the 7.3L is better at getting rolling under load, but once you're rolling you're getting passed, right? Or, is the 1600 RPM good for getting the load going, and then you just keep going and going and there is not strength in having the peak power at a higher RPM.
See, I just don't get the RPM arguments. I can get a 20,000 lbs load rolling with a V10 or 5.4L truck, but maybe not as quickly. Is that the argument? If so, what about after it's rolling?
Old Jul 6, 2009 | 04:30 PM
  #280
Ace!'s Avatar
Ace!
I'll...and having people turn their heads as I drive down the street because they think the garbage truck is coming.
Maybe it is.
Old Jul 6, 2009 | 04:35 PM
  #281
EXv10's Avatar
EXv10
Originally Posted by Ace!
Maybe it is.
Lol ...........right on Ace
Old Jul 6, 2009 | 05:48 PM
  #282
mudmaker's Avatar
mudmaker
Maybe someone could post a dyno run off of a V10 and we could see how it's torque curve compares to that of the powerstrokes.
I know the powerstroke's curve peaks early, but the curve is fairly flat. I suspect a v10 curve is much steeper, but I may be wrong. It would be nice to see some actual dyno numbers, not just Ford charts.
Old Jul 6, 2009 | 05:57 PM
  #283
Johnny Langton
So you can compare a graph from a forced induction engine to a N/A engine?
JL
Old Jul 6, 2009 | 06:19 PM
  #284
bill11012's Avatar
bill11012
Modular motor junkie
HP: 362@3250RPM
Tq: 457@4750RPM
HP: 250@2800RPM
Tq: 525@1600RPM
but with the tq at a higher rpm I am running 2ed gear at 60-65 getting all mine to the ground. you are running 65 in OD to have all your tq.
If you multiply the gear ratio ( with both having the 3.73s and 4r100)
It is like this
7.3 = 1390 pound feet to the ground
6.8 = 2625 !
BTW, my 6.8 has a 200 amp alternator.
Old Jul 6, 2009 | 07:04 PM
  #285
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
JL
there you go again with the turbo stuff!
