Sponsored by: Real Truck
Gas vs PSD
Old Jul 6, 2009 | 07:51 PM
  #286
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I will beat the V-10 in pulling and in a drag race. Bring it on big-guy.
ART, is this enough to get the gassers going?
Old Jul 6, 2009 | 08:10 PM
  #287
mudmaker's Avatar
mudmaker
Originally Posted by Johnny Langton
So you can compare a graph from a forced induction engine to a N/A engine?
JL
I didn't think this was a debate on V10 vs 7.3 IDI N/A, the thread says V10 vs PSD.
Then again it would be interesting to see what dumping $7k into a V10 would get you. So if you have the dyno result for a turbo charged V10 you could always post it.
Old Jul 6, 2009 | 09:13 PM
  #288
Ricohman's Avatar
Ricohman
I would drive another 6.0 instead of my present V10 if the damn thing would have been somewhat reliable.
But after bed plate leaks, 2 turbos, egr, injectors, headgaskets I'd had enough. To bad.
Old Jul 6, 2009 | 09:36 PM
  #289
QwkTrip's Avatar
QwkTrip
Originally Posted by Ace!
If the 7.3L you're talking about reaches 1600 RPM it then drops off, right? So, say you are driving over a pass and want to pass a vehicle, wouldn't it be better to have peak numbers at a higher RPM? Are 7.3L only good for pulling stumps? What about once you've pulled the stump and now you want to take it somewhere? So, the 7.3L is better at getting rolling under load, but once you're rolling you're getting passed, right? Or, is the 1600 RPM good for getting the load going, and then you just keep going and going and there is not strength in having the peak power at a higher RPM.
Last time I checked my transmission had gears. You clearly don't understand what you're talking about.
Old Jul 6, 2009 | 09:40 PM
  #290
bill11012's Avatar
bill11012
Modular motor junkie
your truck is not at all stock, my V10 is so you are right.
If I put that much cash into my V10 you would never out tow or out run it.
Old Jul 6, 2009 | 09:45 PM
  #291
EXv10's Avatar
EXv10
And my dad can beat up your dad
Old Jul 6, 2009 | 10:11 PM
  #292
Pinky Demon's Avatar
Pinky Demon
NO WAY! My dad can definitely beat up your dad.
Old Jul 6, 2009 | 10:25 PM
  #293
78bigbronco's Avatar
78bigbronco
Originally Posted by brian42
I'll even spot you the '08 V10 powerplant numbers:
HP: 362@3250RPM
Tq: 457@4750RPM
Now turn the way-back machine to 6 years ago and the last of the 7.3L's:
HP: 250@2800RPM
Tq: 525@1600RPM
I will admit that the numbers dont lie and 'overall' the diesel is gonna outpull the V10. However just because the V10 peaks at that high of RPM doesnt mean it drops to nothing down low. I'd like to see some torque curves... I havent seen any lately but I'd amagine the V10 still haas a good percentage of power available down to ~2,000.
And for the money and extra complexity and such of the diesel I would hope it would be the strongest towing choice. But for most of us the V10 does nearly as good and has some other advantages to so it has a lot to do with specific applications and indivudal preference.
Old Jul 6, 2009 | 10:27 PM
  #294
mudmaker's Avatar
mudmaker
I found a dyno of a 2V V10. Shows stock rwhp is 211 and torque is 273.
Here is a link. You have to select the motor on the list.
http://products.jbaheaders.com/dyno.asp#
Old Jul 6, 2009 | 11:11 PM
  #295
Ace!'s Avatar
Ace!
The PSD and V10 both have transmissions. The post I was quoting wasn't referencing the transmission, or the differential gears, but RPM. I clearly understand not only what I was talking about, but what the poster that I was quoting was talking about. You understand I was referencing/quoting a specific post, right? By the way, I don't believe you've ever checked your transmission for gears. I just don't buy it. I believe it has them, but I don't believe you ever checked.
BTW, doesn't the "argument" that your truck's tranny has gears works both ways? Doesn't the V10 truck also have gears in the transmission which allows it to get a load moving, a lower 1st gear and higher "highway" gears? If the "argument" is the 7.3L truck has gears to keep the load rolling down the highway doesn't the same argument hold true for any other truck, that it also have gears (lower) to get the load moving?
Old Jul 7, 2009 | 12:18 AM
  #296
bill11012's Avatar
bill11012
anybody can beat up my dad.
Old Jul 7, 2009 | 12:20 AM
  #297
bill11012's Avatar
bill11012
what made the 6.0 better than the V10?
Old Jul 7, 2009 | 02:04 AM
  #298
vypr's Avatar
vypr
PSD is way better
All I can say is if you really wanna know what the difference is go get
14,000 lbs of fifth wheel and go pull it up one of Colorado's 12,000
ft mountains and you will see what the difference is. I traded my v10 in for the 7.3 PSD and have never looked backed.
Old Jul 7, 2009 | 02:18 AM
  #299
Sparky83's Avatar
Sparky83
i dont really feel like reading through 20 pages of debate... yes id like a v10 but same ways lately with the flop in whos cheaper at the pumps ive been considering diesels..
now ive seen yall have the hp/tq debate already in the first 2 pages... and looks like its still continuing on this last one...
my question is... Ive ALWAYS!!! heard that with diesels short trips are hard on the engines... where with gassers theyre not.. or at least not as badly on the gassers as on the diesels.. im just wanting to know if its true...
like for instance.. if i were to drive.. say 5-10 miles down the road.. which engines being hurt more from a trip that short?
Old Jul 7, 2009 | 07:19 AM
  #300
mongo75's Avatar
mongo75
Even w/o forced induction, a diesel will always have the low end grunt a gas engine doesn't.
Garbage truck??? So what kinda engine is under the hood of the tow truck that comes to get you when you blow a spark plug out?? That's right, a DIESEL....
M75 - hey guess who I am LMFAO!!!
