Sponsored by: Real Truck
Gas vs PSD
Old Jul 4, 2009 | 01:37 PM
  #241
scraprat's Avatar
scraprat
Top Answer: 5
Originally Posted by Krewat
Nope, it's become a contest to see who can urinate further
Gave up on the thread. But, now we are peeing I'm in.
http://smiley.onegreatguy.net/pee.gif
Old Jul 4, 2009 | 05:46 PM
  #242
Tom's Avatar
Tom
Not to offend anyone here, but this thread is sounding an awful lot like middle school playground chatter rather than a real discussion. Of course, I have nothing against beer or peeing contests or anything else of the sort, but the actual argument is just getting dumb here.
Both sides are so insistent that theirs is the best for whatever reason they can dream up that nobody is ever gonna win this debate, nor convince one of the true believers on the opposite side of the fence the error of their ways.
Seriously, this is just dumb! For the record, HP matters. The V10 when pulling at peak HP WILL pull harder than my 6.4 will short of aftermarket modifications. But that 12 HP advantage is only 3.4% higher than the diesel, so it's a relatively insignificant difference.
Both will pull heavy things up big hills. Beyond that...who cares?
Old Jul 4, 2009 | 06:29 PM
  #243
QwkTrip's Avatar
QwkTrip
Having agreement isn't necessary to win an argument.
Old Jul 4, 2009 | 10:54 PM
  #244
bill11012's Avatar
bill11012
Modular motor junkie
so i think the debate is over.
the V10 and 6.4PSD pull about the same.
The V10 is cheaper.
The MPG of the V10 is slightly less.
both will give a long service life.
So can we all agree know that are trucks are the same?
The V10 guys love them and the PSD guys love them, so we should all be on the same side of the fence! ( the blue oval side!!!)
Old Jul 4, 2009 | 11:06 PM
  #245
hughjazz's Avatar
hughjazz
I think the closest apples to apples test would be
diesel with 3:73
v10 with 4:30
keeps both in the proper rpm range.
to say a v:10 won't pull as well as a diesel with 3:73s is flawed logic.
The diesel is at it's best at relatively low rpm
the gasser is at it's best when it's wound up.
both make incredible power, both make diffrent "feeling" power.
which is better?
depends.
It depends on personal choice.
there is no question that either will do the job more than adequately
Hell I currently have the v8, for me it's the right choice.
*translation* there is no universally better choice.
As long as it's a sd, you made the right choice.
Old Jul 4, 2009 | 11:23 PM
  #246
EXv10's Avatar
EXv10
Actually they both have advantages and disadvantages. Personally I don't like the noise pollution and the smoke of a diesel but everybody is different. What is strange is that the 2 stroke smoke and the noise from my snowmobile doesn't bother me. Actually I think the diesel sounds like it has a bunch of broken piston skirts and smokes like it has broken rings to boot. :
Old Jul 4, 2009 | 11:33 PM
  #247
150ford's Avatar
150ford
Them diesels are not that noisy. I cant here mine in the cab. Pollution well dont notice that either. Simple fact a diesel will pull a load better then the V 10. You have to own a diesel to say that an I do. The V 10 will get the job done also. The torque on a diesel is really hard to beat. Id say if you pulling heavy loads all the time get the diesel. If you occassionally pull a load. The V 10 will work just fine. That should please everybody.
Old Jul 4, 2009 | 11:35 PM
  #248
EXv10's Avatar
EXv10
I think them thar diesels used to be noisier.
Old Jul 4, 2009 | 11:47 PM
  #249
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
I bet my new 6.4 is Quieter then you V 10!
Old Jul 5, 2009 | 12:33 AM
  #250
EXv10's Avatar
EXv10
I think they are quieter these days. They were pretty annoying (like in the old Mercedes cars) clack, clack, clack......
Old Jul 5, 2009 | 01:21 AM
  #251
Pinky Demon's Avatar
Pinky Demon
You've obviously never owned a 7.3.
Old Jul 5, 2009 | 06:15 AM
  #252
CampSpringsJohn's Avatar
CampSpringsJohn
Make no mistake, the 7.3 ain't the engine to have if you're trying to sneak around and be quiet!
Old Jul 5, 2009 | 08:13 AM
  #253
bill11012's Avatar
bill11012
The V10 will get your truck off the line, when your turbos are spooled up your 6.4 will pass my truck. When I get up over 4,000 RPM I will go by you.
The thing is the V10 can turn more revs, meaning you can run a lower gear and get more power and tq to the ground. Midrange is the only place a 6.4 can outpull a V10.
What is the red line on a 6.4PS?
Old Jul 5, 2009 | 08:44 AM
  #254
150ford's Avatar
150ford
No I own a 2003 7.3. Have for five years. Them older 7.3 were a bit nosier though. Mine is not bad at all inside or outside the cab.Good points Bill. Cant argue with you there. Them new 6.4s are pretty quiet.
Old Jul 5, 2009 | 09:00 AM
  #255
CampSpringsJohn
I will admit, my 97 is much noisier than my 02. The HPX I installed on the 02 helped out some too.
