Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
No topic thread,,, Part 2
Old Feb 17, 2009 | 03:02 PM
  #2326
FORD RANGER's Avatar
FORD RANGER
i have tools that i used all the time and specialty tools that i use once in a while.
like a ford cam synchronizer tool for example. i used it once in 3years.
and now i don't use any of them.
Old Feb 17, 2009 | 03:37 PM
  #2327
less's Avatar
less
Originally Posted by 55 Merc M-100
How long are you guys going to go on about tools??? In my opinion, tools are like most things. You get what you pay for. But I also look at it this way, if you don't use something every day, do you need the best one out there or will the middle of the road one do the job and save you $$ along the way. OOOPPPPs, there's that female logic again.
Well Sharon...we guys like to go on about tools because that is just one of the things that guys do...and do well, I might add.
Regarding your second point about female logic again....well years ago, if I wasn't working with a tool every day...I did what you suggest....I went the econo route, just get a tool that wasn't too expensive, but that I figured would do the job...occasionally.
In my case I did that with drills...I bought low end consumer drills. But I found about every 3-5 years I had to replace them as they burn't out. Because once in a blue moon I would use this occasional tool for a heavy duty job. The consumer level drills couldn't hack it started to slip and then smoked , then stripped gears, or burn't up their windings...or whatever they burn up in there. I'm no expert on how a drill works, I just know when it doesn't work and what precedes the breakdown, from my sorry, past experience.
So I went to a prof. carpenter's retail tool shop and asked them what I should get, given my frustration. They sold me a Black & Decker Industrial drill for the princely sum of $ 126.
I've had it for 20 + years and although I just use it occasionally and ever so often have a real tough job...it has not failed me yet. Considering that the first consumer drill(also a B + D) cost me $30 (going back 25 years +, lasted 3-5 years, the second consumer drill (B+D again)...lasted 3 years....I figure in the long run this Industrial Black and Decker drill...fit for a pro carpenter...will last me my lifetime, then maybe my son will inherit....or ...my daughter.
I think in the long run, it's more expensive initially to buy, but then has proved more economical over a long period of time, due to it's comparative durability and reliability.
One other thing...I find it a real pleasure to use a really good tool....the way they work efficiently , the way that when using a really good tool...I find because of their build quality and better tolerances, that my finished work is better . I think it's because an excellent tool...just tends to do the job much better and faster. I don't get frustrated like I do with poor, lower end tools, I actually enjoy the work with a fine tool.
Before I as retired in my career, I had to write longhand a lot. Daily. I found that the pens I used were generally expensive , but made writing easier. I used Sheaffers' White dot, fountain and ball point pens. The difference between these pens and a cheap Bic, was amazing to me. I bought them myself.
Old Feb 17, 2009 | 04:38 PM
  #2328
FORD RANGER
most of my tools are hand,cordless,air. i've only had to replace very few of them in the last 25 years. due to wear or breakage or loss.
Old Feb 17, 2009 | 05:43 PM
  #2329
Fomoko1's Avatar
Fomoko1
Now I have all the needed tools I need more tool boxes/roll-a-ways but between the welders, plasma, benches, air compressors and storage cupboards I`m totally out of shop floor space............
Old Feb 17, 2009 | 06:10 PM
  #2330
FORD RANGER
were you going to put your cupboards in your shop is good!
Old Feb 17, 2009 | 06:21 PM
  #2331
Fomoko1's Avatar
Fomoko1
Jack, there was a sale on some nice Rubber Maid garage cabinets. I found out that they`re alot of work to put together and the shelves are too short for my new tool trays......Back to sq one!
Old Feb 17, 2009 | 06:39 PM
  #2332
96sherm's Avatar
96sherm
well sharon, i gotta dissagree with your female logic... if you only got to do the job once, find a GOOD QUALITY tool to rent or borrow, or get someone else to do the job. using the female logic, buy a cheap tool to do the job once, often results in broken parts or wasted materials because you were too cheap or impatient to do it right/get it done right...
Old Feb 17, 2009 | 07:00 PM
  #2333
FORD RANGER
sherm,
i agree!
Old Feb 17, 2009 | 09:39 PM
  #2334
96sherm's Avatar
96sherm
great minds think alike Jack...
Old Feb 18, 2009 | 12:54 AM
  #2335
FORD RANGER
yes we do sherm! i think we all do at 1 point! thats what makes us guys, guys!!!
Old Feb 18, 2009 | 07:10 AM
  #2336
pmasley's Avatar
pmasley
Sherm and Jack, I agree to, buy quality now and you don't have to buy for a while. I used to only buy Craftsmen tools until lately. It seemed that I was breaking a lot of sockets on things that did not break earlier. I them started checking and found out that now a lot of the Craftsmens sockets and rachets are now made in China. Quality went out the window and those Craftsmen tools went into the trash. Snap-on is just too expensive and you are just buying a name. I started buying my hand tools from Lowe's over the past few years. I cannot think of the name right now, but they are quality tools, not expensive and they do have a replacement warranty. Break it and take it to Lowe's and they will replace it on the spot, no questions ask. I had to use a 19 mm deepwell base socket on an impact wrench. I know that it was a no no. After breaking loose about twenty bolts the socket started to expand to the point that it was close to a 20 mm. I took it to Lowe's, the tool man knew what I had done, but smile and gave me a new on, then sold me an impact set for about 45% off of retail. Just to get my future business. And guess what, he did. I bought an entire new set from him later on.
Old Feb 18, 2009 | 01:18 PM
  #2337
55 Merc M-100's Avatar
55 Merc M-100
Sherm, I didn't say buy a cheap tool, just not a proffesional one if you know you will ONLY use it occassionally. Hubby has Craftsman and Mastercraft and none of them have let him down yet. Drills are another story. That's something that will get used a lot, no matter who you are. Thats definately worth while to spend the money on. I also agree with the getting someone else to do it for you if you don't have the right equipment. Thats why someone else built our second garage last summer. We would have had to borrow too much from people or rent it. Scaffolding was the biggest problem since we put in 10 ft walls. Besides, it was great to sit after work and watch them do the work while we had a beverage!
Old Feb 18, 2009 | 04:31 PM
  #2338
FORD RANGER
kobalt tools paul.
i bought a set of 1/2" drive deep impact sockets back in the late 80's that i still have and i've never broken one. and i think i gave 20$ for the set from harbor freight.
i have all sorts of brands and used all sorts of brands of tools and broken some of the more spendier brands in my day. thank god for a warranty. i have a 1/2" drive bluepoint
air impact thats rated at 800 ft.lbs.reverse and 750 forward it will twist bolts off if your not carefull.
i guess over the years i have boughten 40,000$ worth of tools. and thats for boxes hand tools,cordless,and air tools. and i'd like to say that i'm a proffesional mechanic.
and have been for many years.
Old Feb 18, 2009 | 04:39 PM
  #2339
96sherm's Avatar
96sherm
why would you need scaffolding for a 10ft wall??? i built a shop with 10ft walls a little while back, no scaffolding needed... its called wall walking
Old Feb 18, 2009 | 07:34 PM
  #2340
preppypyro's Avatar
preppypyro
I go away for a few days and miss most of the tool talk, damn!
