lets see the supercabs!!!
Old Jul 9, 2019 | 08:19 AM
  #1006
mpqualdie's Avatar
mpqualdie
Old Jul 9, 2019 | 09:08 AM
  #1007
Redrokin09's Avatar
Redrokin09
Sure is a beautiful truck you have there.
Old Jul 9, 2019 | 11:37 AM
  #1008
CharlieXLT's Avatar
CharlieXLT
Originally Posted by mpqualdie
I had the engine rebuilt in my 78 F-250 Supercab 2 years ago and the top half went bad. I didn't realize I had to use special oil in it to protect the camshaft and it ate itself up..
So what's this special oil? I had the engine in my supercab rebuilt last year. What kind of oil had you been using?
Perhaps we should tell the 5.7L Dodge owners about this special oil, too. That engine has a bad habit of ruining camshafts.
Nice looking rig. I think I should get the windows tinted in mine, also.
Old Jul 9, 2019 | 12:16 PM
  #1009
mpqualdie's Avatar
mpqualdie
If you retain the flat tappet camshaft you need to run a Zinc additive to the engine oil. According to my engine guy, the federal government a few years back banned the use of minerals like Zinc in the engine oil to cut down on pollution. So now my research is telling me to use Rotella 15w-40 or similar oil that's made for older equipment. As well Lucas makes a Zinc additive for your oil that costs about $20 a pint. If you upgrade to a roller cam none of this is necessary, but the flat tappet cams need the minerals to properly lubricate the cam. You can also buy "hot rod oil" that already has it, but very expensive per quart. I have always used Castrol full synthetic in all of my cars/trucks for years and have gotten a couple hundred thousand miles out of them. But he says the modern oil doesn't coat it sufficiently.
That picture was 5 years ago the day I bought it. it's a little more weathered now, but still good. The motor and trans are original to the truck. I had the 351M built with a thumper cam and 40 over bore. It's not very fast, but boy does it turn heads when I pull into a parking lot. With the dual Flowmaster exhaust and the thumper cam that thing sounds amazing and a lot tougher than it really is. Before and after motor pictures. It now has an HEI distributor and a spacer under the air cleaner for HEI clearance.
Old Jul 11, 2019 | 09:25 AM
  #1010
Redrokin09's Avatar
Redrokin09
Those valve covers are sweet, Wish I could find something like that for my 460
Old Jul 11, 2019 | 09:37 AM
  #1011
mpqualdie's Avatar
mpqualdie
Should be the same as on the 351M, I thought 351M and 460 used same head style. These were about $200 at Summit Racing. I liked them so much I used the same ones on my 86 Bronco restoration. You can see my Bronco in the Bronco section of this Forum.
Old Jul 15, 2019 | 06:03 PM
  #1012
hail destroyer's Avatar
hail destroyer
That supercab is awesome
Old Jul 30, 2019 | 02:54 PM
  #1013
Redrokin09's Avatar
Redrokin09
Spent a few days polishing mine up really good.
Old Jul 30, 2019 | 03:02 PM
  #1014
somethingclever's Avatar
somethingclever
looks amazing...just need about $80 worth of stainless fasteners for the mirrors and you'll be set!
  #1015
Redrokin09's Avatar
Redrokin09
Thanks, that's true enough...
Old Aug 5, 2019 | 02:00 PM
  #1016
Ben Samways's Avatar
Ben Samways
Fellow Utahn! Nice truck!
Old Aug 5, 2019 | 02:31 PM
  #1017
Redrokin09's Avatar
Redrokin09
Haha... Thanks for the compliment, I'm in Springville
Old Aug 9, 2019 | 06:08 PM
  #1018
thatsrealnice's Avatar
thatsrealnice
Polished up beautifully!
Old Aug 9, 2019 | 06:10 PM
  #1019
thatsrealnice
Mine today
My truck of many colors. Got a new windshield put in today. Going to go pick up master cylinder in a few mins and replace that. Rebuilt rear brakes, brake hoses, some of the hard lines, bearings, races.
Old Aug 12, 2019 | 10:56 AM
  #1020
broktruk's Avatar
broktruk
Just posted on the Craigslist find of the week page. Supercab group....here's a FREEBIE! plus parts.
https://oregoncoast.craigslist.org/z...954517855.html
