lets see the supercabs!!!
Old Jan 5, 2018 | 06:30 PM
  #856
rougeriver's Avatar
rougeriver
Wow, Brett, that's a really good looking SuperCab! So clean and slick!
David
Old Feb 18, 2018 | 01:16 PM
  #857
Vitality's Avatar
Vitality
my 79
i picked this up in new york its from utah i believe
Old Feb 18, 2018 | 03:15 PM
  #858
Behemoth's Avatar
Behemoth
Looks like you got a good base to work with....some body stuff here and there (like the leading edge of the cab roof...that can bite you if left long enough), but overall very straight. Looks like you got a straight, original grille shell, and as most folks here will testify to, those are getting to be hard to find. I'm not a monster fan of the racetrack trim, but it does work well with a two-tone paintjob. I like the color layout....classic. Now you gotta let us know what the plans are for the future of this beastie!
Old Feb 18, 2018 | 05:22 PM
  #859
somethingclever's Avatar
somethingclever
In the middle of installing highboy front springs.....
Old Feb 18, 2018 | 05:30 PM
  #860
Vitality's Avatar
Vitality
i like the original paint some of the brown has been touched up and the bottoms of the door jamb but overall i like the ruff look of the old paint, what exactly is the race trim? it seems like the trim acts as a brush guard for offroad use is what i was thinking
Old Feb 18, 2018 | 10:31 PM
  #861
Behemoth's Avatar
Behemoth
The 'racetrack' trim I was referring to, is the thin piece of trim that goes from the front main beltline trim piece that mounts in the 'dent' of our dentsides, and it follows the perimeter of the bottom of the vehicle and goes over each wheel well, and comes back up to the rear of that same long straight trim line.......thus, completing a sort of racetrack. Some trucks came with that, and some had just the main straight trim along the side, depending on model. I mentioned it, as I believe two-tone paintjobs to look better when the truck has the racetrack trim. Trucks like mine with only the straight beltline trim, seem to appear better in a single color, IMO. As for any of the trim acting like brushguards, I think you're giving it way more credit than it deserves. The trim on these trucks was mostly anodized aluminum, and it doesn't take a beating very well.
Old Feb 22, 2018 | 12:24 AM
  #862
black & blue 78/9's Avatar
black & blue 78/9
W O W!!!!
I've spent the last three days reading all 58 pages. ALot of really nice trucks. I also like seeing the other ones also. Dont feel so bad about my wifes ride.
Old Feb 22, 2018 | 12:31 AM
  #863
black & blue 78/9
Highboy springs
Hello somethingclever. Are the HB springs a straight swap in or is there hanger mods that need to be done?
What about the front driveshaft? Stock lenthor need to make longer? Complete front pack or select few?
Old Feb 22, 2018 | 07:44 AM
  #864
somethingclever
THe only issue is HB uses 9/16" front bolt in front spring where-as 78-79 uses 5/8" bolt.
I changed out the front bushings to RB151 which is 1/8" too long. I removed the excess from each end down to 3 3/8" and installed them in the new springs.
The lift was only 1.5" over stock so no issues with driveline.
Old Feb 22, 2018 | 08:59 AM
  #865
black & blue 78/9
HB bushing
We have a 79 F150 4x4 Super Cab with a health 400, 33s, C6. Would the HB springs net we more than 1.5" of lift?
Also, the bushings you referenced, did you shave off from the inner part of the bushing, the part that goes in the spring eye, OR from the outer part that goes between the spring eye and the frame bracket to make it shorter?
If I can figure out how to post a pic of my ride, I will. I have never posted a picture on the web before.
Old Feb 22, 2018 | 11:20 AM
  #866
somethingclever
What is the distance from your axle centerline to the bottom of the front fender sheetmetal? 21 1/2?
Old Feb 22, 2018 | 12:50 PM
  #867
mofoco1's Avatar
mofoco1
well motors getting pulled on the 75 SC
Well decide to freshen up the 75 390 while its easier. Ordered new Manifold, Hei Ignition, Carburetor, still researching Cam(suggestions on a usable daily/tower/ toy all around in other words?) Also, anyone done the Sagniaw canned ham to 390 baracketry swap? Pics and P# would be cool.
It's decided, it's coming out!!!!!!!
Old Feb 24, 2018 | 01:03 PM
  #868
dragond80's Avatar
dragond80
1975 supercab
Old Mar 8, 2018 | 07:51 PM
  #869
buckrogers22's Avatar
buckrogers22
Just got my Supercab
Just got this home, found in Middle TN. Barn find. Will start the clean up and get it started
Old Apr 3, 2018 | 09:13 PM
  #870
LaserShark's Avatar
LaserShark
Originally Posted by fdude64
does anyone have pics of their supercabs? heres mine as it is now.
​​​​​​Here's mine
