lets see the supercabs!!!
Old Dec 8, 2017 | 10:37 AM
  #841
bam8850's Avatar
bam8850
1979 supercab 4x4
I don't really want to do this but.....
eBay ad.... https://www.ebay.com/itm/11267868205...84.m1555.l2649
craigslist ad..... https://delaware.craigslist.org/cto/...413663357.html
Sad times...
call or text 302 381 4580
Old Dec 9, 2017 | 12:45 PM
  #842
SupercabTJ's Avatar
SupercabTJ
Dunno why it took me so long to post mine, but here she is enjoying the beach
Old Dec 11, 2017 | 11:16 PM
  #843
fordman67's Avatar
fordman67
Originally Posted by fordman67
Attachment 192181
going in 2 weeks to get my new to me 1976 f150 xlt ranger "trailer special" 390 "m" code ,auto . very excited to get back to my roots a bit!
Welp, drove the pile the last half summer. I'm gathering body panels and pieces for work to get started. Sadly the ol gal is to well "ventilated" at present for winter use.
Old Dec 11, 2017 | 11:20 PM
  #844
fordman67's Avatar
fordman67
Luckily a fellow fte'r snatched this up for me in OK. Im gonna make something out of this 76' !!!!
Old Dec 26, 2017 | 03:51 PM
  #845
Kierobi's Avatar
Kierobi
Who's replaced the carpet in their SuperCab and where did you get the new one from?
Looking to put one in mine because the carpet it came with just looks nasty now and having a hard time finding one for a decent price
Thanks in advance!
Old Dec 26, 2017 | 04:47 PM
  #846
Hale's Avatar
Hale
Thanks in advance!
I went with Automotive Interiors (http://www.automotiveinteriors.com), cut pile with the insulation (mass backing?), $230 total. Looks nice. Others have mentioned ACC, think they are respected.
Mike
Old Dec 26, 2017 | 11:42 PM
  #847
march's Avatar
march
Got mine through stockinteriors.com Also ACC carpet. Pleased with the product.
Old Dec 28, 2017 | 04:03 PM
  #848
Kierobi's Avatar
Kierobi
Originally Posted by Hale
I went with Automotive Interiors (Automotive Interiors & Accessories for cars, trucks, vans, & suvs), cut pile with the insulation (mass backing?), $230 total. Looks nice. Others have mentioned ACC, think they are respected.
Mike
Thanks for the info. Sorry been a while getting back onto the forum!
I looked into both Stock Interiors and Automotive Interiors and there is a MASSIVE difference in the price incl shipping between the two with AI being the cheaper. They both seem to be the same ACC carpets sold with the same options.
You said you were pleased with your carpet right? Think I'm going to follow in your footsteps and go with AI. Any huge amount of trimming you had to do? Thanks for the help and advice!
Old Dec 28, 2017 | 05:41 PM
  #849
rougeriver's Avatar
rougeriver
I ordered my carpet from ACC, and got it with the mass backing. I'm happy with it, but my mistake was in not removing it from the box when it first arrived. I left it all folded and rolled up for a few months until I was ready to install it, and some of the wrinkles were set permanently. The mass backing held them in place, mainly on the hump, and no amount of heat would relax them out. It's kind of like a Shar Pei in that area.
David
Old Dec 28, 2017 | 09:13 PM
  #850
Kierobi's Avatar
Kierobi
David
Looks a sweet rig man. Had to look pretty hard for the wrinkles and you told me where they were. Been looking into it some tonight and Automotive Interiors use ACC products, so think I'll be going with them to save a little $$$.
Do have to ask you though, the grommet around the high beams switch. Where'd you find that? Would like to finish that off nicely while I'm replacing the carpet and I am thinking about getting a little rubber boot like you find on the bottom of walking sticks to make it non-slip!
And how in the heck did you put three point seat belts in the back??? I've got lap belts and the same bench seat and would love to put another set of three points in the back! I've done the front ones but not without a bit of messing about extending the buckle side. Need to know where you got all the seat belts now!
Old Dec 28, 2017 | 09:49 PM
  #851
Jason May's Avatar
Jason May
7th Gear
My work in progress
Old Dec 28, 2017 | 10:58 PM
  #852
rougeriver's Avatar
rougeriver
The dimmer switch grommet came with the new carpet, if I remember correctly.
As far as the rear shoulder belts, this is a cut and paste from an earlier post:
I haven't done a write-up on my seatbelts, I guess I should. I got the seatbelts from a late '80's early '90's SuperCab, the retractor mounts to the original seatbelt mount, the upper anchor to the sidewall, and the end mounts using one of the rear seat floor bolts.
I reinforced the upper mount by splitting the welded seam of the SuperCab side window, and dropping a plate from the top open access with a tab that I could weld through that seam. The plate has a hole with welded nut that lines up with the drilled hole. No paint work was needed this way.
I dyed the belts black using SEM. They look and work great.
It all sounds much more complicated than it actually was.
David
Old Dec 29, 2017 | 08:55 AM
  #853
hickory1991's Avatar
hickory1991
David
David, you sure have your interior looking great. Love all the touches you have done.
Old Dec 29, 2017 | 10:16 AM
  #854
rougeriver's Avatar
rougeriver
Thanks hickory. I appreciate It!
David
Old Jan 5, 2018 | 05:35 PM
  #855
Brett73-79's Avatar
Brett73-79
78 f150
