Project:10 Second F100
Old Apr 2, 2008 | 05:55 AM
  #241
tankrsc's Avatar
tankrsc
looks like you have a yard full. If you need I can come up and clear out some of that stuff for ya
Old Apr 2, 2008 | 10:53 PM
  #242
mwvdub's Avatar
mwvdub
That is not all my stuff. That is a friends house where the Americans were. He would be more than happy to clear it out though.
Old Apr 3, 2008 | 06:08 AM
  #243
tankrsc's Avatar
tankrsc
I don't have near that much and my wife wants me to clear some out
Old Apr 6, 2008 | 10:10 PM
  #244
mwvdub's Avatar
mwvdub
Just like everything else that we have done this year the engine was a fight. When we switched from the 300 V6 to the 460 a few years ago we just got a set a stock towers and welded them in and bolted the engine down. This season we got some Trans-Dapt engine swap mounts which mounted to existing 3/8" holes in the front cross-member. When we got the engine set in the bay and bolted done the whole engine and transmission assembly was moved back 2 1/8" from the old mounts which makes the drive-line too long and the throttle linkage a real mess. On these trucks also the engine and transmission as stock seems to be set to the passenger side of the vehicle about 2". So we had to modify the mount for the tranny. All in all a couple hour job took about a days work to get it straight and level.
Got the alternator and all wiring done along with the fuel plumbing and one header. The other needs a 5 inch piece cut out to fix where it was massaged to fit when the engine was on the old mounts and foward 2 inches from where it was supposed to be. The other was coated with VHT flame proof enamel and baked in the oven for a few hours.
Old Apr 7, 2008 | 05:54 AM
  #245
tankrsc's Avatar
tankrsc
Getting closer by the day
Old Apr 7, 2008 | 11:40 PM
  #246
droppedf100's Avatar
droppedf100
Thats sucks about the mounts but at least moving the motor back will help hooking. Everything looks great. You need to get a side picture so I can see the stance with the motor in it.
Old Apr 8, 2008 | 06:03 AM
  #247
IZZYAZ's Avatar
IZZYAZ
I am in the process of rebuilding my first engine (with help of a few buddies of course). And I hope my engine looks half as nice. Of course mine will be built for the street and torque, but that thing is a piece of art work.
I need to get me one of those mini sand blasters so I can clean up my parts and powder coat them.
Old Apr 8, 2008 | 07:56 AM
  #248
mwvdub's Avatar
mwvdub
Plan on taking it out on a drive on saturday so I will get some good shots out in the sun. We had to put the front on blocks to get the transmission and engine in together so it looks like the truck is pulling a 6 inch wheelie right now and the stance looks a bit weird.
Old Apr 8, 2008 | 07:58 AM
  #249
mwvdub's Avatar
mwvdub
Good luck with the engine rebuild and thanks for the kind words. I highly recommend the powder coating.
Old Apr 9, 2008 | 09:11 PM
  #250
mwvdub's Avatar
mwvdub
Picked up the shortened drive shaft today and some new 5/16 line for the tranny cooler. All I need now are some spark plugs and go for a test drive on saturday.
Old Apr 10, 2008 | 05:20 AM
  #251
150ford's Avatar
150ford
Engine looks awesome. Hope she runs as good as it looks. It will be great to see some Ford power racing down the strip an doing some damage. Be prepared for some compliments. Somme ooohing an aweing when looking at your truck. I can just here it now. Boy thats one fast truck. Make sure somebody takes a video. I cant wait to see it run down the track. Good luck
Old Apr 13, 2008 | 10:15 PM
  #252
mwvdub's Avatar
mwvdub
Still not fired yet but getting closer. The guy doing the tin work in the box finished the tubs and the tunnel between the two on Saturday so we got it all primed and caulked. Also got the drive line and drive line loop finished up. On the engine we got the radiator in, the starter back on and the headers done. Also made up some collector extensions and some 3" exhaust dumps so totally eliminate the mufflers.
Since the engine is set back the radiator hoses are too short so we need two new ones. Still need to drop in the distributor, install the plugs, fill the radiator and drive.
Old Apr 19, 2008 | 07:50 PM
  #253
mwvdub's Avatar
mwvdub
It's alive! Fired it up about 3 this afternoon. Pictures and a movie tomorrow when I can get away from dial-up internet.
Old Apr 19, 2008 | 08:11 PM
  #254
bucks77ford's Avatar
bucks77ford
Awesome.......Can't wait to see that. You have a really kickA$$ truck there.
Old Apr 19, 2008 | 08:35 PM
  #255
tankrsc's Avatar
tankrsc
can't wait
