Project:10 Second F100
Old Feb 17, 2008 | 12:27 AM
  #166
mwvdub's Avatar
mwvdub
Originally Posted by tankrsc
here are a couple pics of trucks that run our 1/8 mile Wildcat track down here. They both run in the 7's pretty easy, 460 in both, both run C6. Both could go faster if the track would hook alittle better
What is the elavtion where you run the 1/8th? I have always run in the low 8's in the 1/8/ The track we run at is 4600 feet and the track in denver has to be over 6000 feet. Just to get an idea of what the difference is. Our air is pretty thin.
By the way both trucks look great.
Old Feb 17, 2008 | 04:35 PM
  #167
tankrsc's Avatar
tankrsc
We are about 302 feet above sea level here. Not quite as high as yall
Old Feb 17, 2008 | 08:08 PM
  #168
mwvdub's Avatar
mwvdub
Pictures of power coated intake and valve covers that we did last weekend.
Started engine assembly on saturday. Everything went well until the pistons were put on the rods backwards leaving the valve reliefs in the wrong place. Took the spirolocks off and switched them around. COntinued on until it was time to put the oil pan on. it doesn't fit anymore since we are running a stud girdle and a windage tray. Spent most of today modifying it to fit.
Old Feb 17, 2008 | 08:13 PM
  #169
Colo79Ford's Avatar
Colo79Ford
Lucky you are using floating pistons. The Machinist i trusted to press my pistons and rods together pressed the pistons on backwards. Pressing them off crushed the skirts of the pistons a little bit. Thats why i am now running a $500 junkyard engine.
What did you have to do to the oil pan to get it to fit?
Heads look nice.
Got a quick video of the dodge now on youtube from yesterday. Tomorrow im going to get the steel i will need to build my trans crossmember, driveshaft loop, and lift bars. Hopefully tomorrow by 3PM ill be out on the street in it..
http://youtube.com/watch?v=5UvUS1Y5YA4
Old Feb 17, 2008 | 09:33 PM
  #170
tankrsc's Avatar
tankrsc
That motor is looking good Would like to know what you had to do to the oil pan also. By the way the 2-tone Ford on the lift looks pretty nice too how bout some pics
Old Feb 17, 2008 | 10:19 PM
  #171
mwvdub's Avatar
mwvdub
The dodge sounds good. Hope the road test goes good. take the camera with you and get a video for us.
The whole deal with the pistons was a PITA. what I found weird was that only 6 of the pistons were wrong and not all 8.
We bought a canton girdle and a windage tray with a guarantee that they would fit with a stock pan. Called the guy on saturday and he said that they would only fit with a front sump oil pump. the front sump is kinda backwards for hard launches since all the oil wants to go to the back. So we had to cut down the riveted mount for the rear sump dipstick and weld in a patch piece that cleared the girdle. Also last year when the rod broke and rattled around causing all sorts of hell the pan got all spread out and the rails got knocked down about a 1/4 inch. Cant afford a new pan so we had to make do with the old one. finally got it fitted today about 3 but I had to head back home for the weekend. Ordering a pushrod length checking tool to see what we need and the rest should be pretty easy.
A few pictures of the sleeper two tone f100.
WE also put on our sponsors decals and a bunch on the rear of the box to cover up where the box fell off the saw horses and smashed into the engine hoist.
Old Feb 18, 2008 | 12:16 AM
  #172
Colo79Ford's Avatar
Colo79Ford
Will defiantly have a video with me or of me on the first road test.
Nice work with the oil pan. I know oil pans can be a royal PITA after an engine comes apart. Thankfully all of the engines i have had come apart destroyed everything on my engines except for the intake, carb, and headers (even the brand new aluminum heads and nicee milodon oil pans)
Whats the 2 tone f-100 run and whats all done to the engine?
Old Feb 18, 2008 | 08:56 AM
  #173
mwvdub's Avatar
mwvdub
Ya we had to do some welding and hammering to the pan to get into shape. Wish they made a cool racing pan for 1979 f100's with a rear sump but I have yet to find one.
The two tone ran mid 14's last year and smoked like a train since all the valve seals were as hard as diamonds. Brand new 472 with ported Dove-C's and dome pistons this year. Should be about 13:1. also has a hughes transmission with a pretty healthy converter. It belongs to a friend that just started racing a few years ago. We borrowed his shop to do the engine and tranny since our garage door leaks so much air and he has a car lift.
Old Feb 18, 2008 | 05:43 PM
  #174
RNOVRIT's Avatar
RNOVRIT
I believe Mildon makes a large capacity, rear sump pan for a big block. I don't recall the part number but could walk into the garage and take some measurements if you wish. It is on my 528 that is currently sitting on a roll-around craddle.
Old Feb 18, 2008 | 07:02 PM
  #175
mwvdub's Avatar
mwvdub
If it will fit a 79 2wd f100 I am in for one. i guess i forgot about milodon but canton and moroso don't make them.
Old Feb 18, 2008 | 07:14 PM
  #176
Colo79Ford's Avatar
Colo79Ford
Milodon oil pan for 429/460 1979 f-100 2wd and 4wd trucks. Rear sump.
Might want to take a look at this one and see if it will work.
Pan $305.95
Pickup assy. $81.95
Oil pump $36.95
Spectre Industries also make an OEM rear sump pan that sells for just under $90. But its out of stock until half way thru MArch, and its a 5qt pan, not too sure how it would (or wouldnt) work with your windage tray.
Old Feb 18, 2008 | 07:19 PM
  #177
tankrsc's Avatar
tankrsc
That 2-tone is one good looking truck Like the sponser stickers too. Both look awsome can't wait to hear how they run this season. Our track has a test-n-tune sesion this coming sunday my Mustang aint ready yet so will run my small block F-100 totaly stock even 2-brl carb but at least it'll go down the track
Old Feb 18, 2008 | 07:21 PM
  #178
Colo79Ford's Avatar
Colo79Ford
Lucky!! Our tracks first test and tune is in about 1 month and 3 weeks. April 12th.
Old Feb 18, 2008 | 07:31 PM
  #179
mwvdub's Avatar
mwvdub
Pan $305.95
Pickup assy. $81.95
Oil pump $36.95
That pan might work. The only part that worries me is the 3.85 stroke with OE rod. we are running a 4.14 stoke with 6.8 rod. It looks deeper than the stock pan so it SHOULD work.
Old Feb 18, 2008 | 08:33 PM
  #180
RNOVRIT's Avatar
RNOVRIT
I thought this was kinda funny. You forgot about Milodon but the guy in your other post torquing the rods is wearing a Milodon t-shirt. LOL! Not making fun of you, just saw it to be kinda comical. HaHa!
