Edge owners: Tuning thread
Old Apr 6, 2007 | 06:16 PM
  #346
soxfan81's Avatar
soxfan81
i got my edge a few days ago and i have it set to level 3. The shift from first to second feels like it jumps. this is with 3/4 to full throttle. how would I change this, should I soften the trans. shifts. Thanks guys
Old Apr 29, 2007 | 10:32 AM
  #347
WhëëlMå1's Avatar
WhëëlMå1
Bump. Been running Level 2 for a few months now, and I see no reason to even fiddle with the tuner again. It provides some good perk out of basic 87 (and its getting more expensive by the day to justify Level 3, 91+).
Old Jul 19, 2007 | 06:13 PM
  #348
boomer08's Avatar
boomer08
Probably been asked before but I have been to the otherside for a year now and just came back. I assume you can use the tuner with the e85 gas or can you.
After thinking about it I don't think you can
Old Mar 23, 2008 | 09:31 AM
  #349
WhëëlMå1's Avatar
WhëëlMå1
Bump for new owners
Old Mar 23, 2008 | 10:00 AM
  #350
F0rdzTuff's Avatar
F0rdzTuff
Question
Originally Posted by WheelMA1
No, level 3 is a minimum of 91 Octane. You cannot run that tune, with 89 (or you can, but you would have to run the timing -1 degree).
What about up here in Colorado? 89 Octane is our 93 Octane in say, California. We start at 85 Octane because of the altitude. 85, 87, and 89 are the flavors up here. I'm interested in the programmers, but not from a cost-savings standpoint.
Old Mar 23, 2008 | 10:02 AM
  #351
F0rdzTuff's Avatar
F0rdzTuff
I also see that it says not to run E85 with the programmer. Is it easy to go back to stock? The reason I ask is that E85 is sitting steady at $1.99 a gallon out here, and I run a mix of it unless I can only find gas.
Old Mar 23, 2008 | 10:18 AM
  #352
WhëëlMå1's Avatar
WhëëlMå1
My Edge is no longer in use (sold the truck, so I'm trying to get rid of all the accessories I had for it), but if memory serves, there is a section in the manual that tells you how to compensate for altitude differences.
Old Mar 23, 2008 | 10:19 AM
  #353
WhëëlMå1's Avatar
WhëëlMå1
It takes about two minutes to change a tune, and the only tool you need is an opposable thumb (unless you are a donkey or something.... suppose you could operate the interface with a stick in your teeth )
Old Jul 18, 2009 | 12:12 AM
  #354
Flash1034's Avatar
Flash1034
I installed my Edge tonight. Awesome. Thanks to all the guys who made this thread what it is. This site rocks!
Flash
Old Jul 18, 2009 | 02:20 AM
  #355
jsoko's Avatar
jsoko
Thumbs up
Flash, if you read all that your the new xpert
I stayed at L3 for a while then went to L2 and have stayed there
you will enjoy it
drive safe
Old Jul 31, 2009 | 06:33 PM
  #356
klook's Avatar
klook
Mileage and such
I actually got the Edge to maybe boost mileage. I know that most people report that they could not keep their foot out of it and that the gauges were worth the price.
So far I have gone through 3 tanks of gas with different settings or octane. First let me say that the difference in my truck is remarkable and I havn't even tinkered with it much.
With the #2 and 87 I got 17 mpg hand calculated. With 89 I got 16.38 mpg. Now I have bumped up the timing a bit (1*) and when I left the yard tonight I couldnt keep the wheels from spinning. Also, I towed some light loads a bit with the 89 and #2 so the mileage is probably as good if not a little better then the 87. With the stock tune I gained 1 mpg by going up to 89 octane. That exactly corresponded with the increased cost of 10 cents a gallon more. I will continue to play with it and I will ad my voice to the "you just gotta get one" crowd.
Kevin
Old Jul 31, 2009 | 06:40 PM
  #357
Groovy Chick's Avatar
Groovy Chick
Former Vendor
Just wanted to let you know that we can write custom tunes if you'd like to utilize your E85 capability. www.phptune.com
Old Sep 14, 2009 | 05:33 PM
  #358
monkey_nuts's Avatar
monkey_nuts
Downhill - Engine Braking
I just ordered the Edge for my 2006 SC XLT, I bought it mainly for the gauges, but I'm wondering if there's a setting that will allow me to stay off the brakes on the way down the canyons. FWIW, I drive up Little Cottonwood canyon ~60 times per winter for skiing, & I'm wondering if this can somehow help on the way down. I expect to receive the tuner/pod tomorrow.
Old Sep 14, 2009 | 07:46 PM
  #359
monkey_nuts
BTW, it has the 5.4L engine, 4x4, no clue as to the gear ratio, transmission model, or things like that.
Old Sep 15, 2009 | 09:07 AM
  #360
jsoko's Avatar
jsoko
this may help you
http://www.fordf150.net/howto/decode.php
