Edge owners: Tuning thread
Old Mar 26, 2007 | 04:40 PM
  #331
NASSTY's Avatar
NASSTY
Originally Posted by shawn001
And my final flog before this horse dies is ....
What happens if I run 87 with 104+ and it's insufficient octane, will it just run crappy, or can I damage my engine (I'll sign your liability waiver if you like...).
I wouldn't risk running level 3 with 87 and octane booster,it could be disasterous.
Old Mar 26, 2007 | 04:49 PM
  #332
Biggziff's Avatar
Biggziff
I've run 87 on level 3....nothing happened. Remember, these tuners don't really change much. The main thing is changing torque at shift and when the WOT fuel mapping begins (TPS). The shift changes make the trucks feel like you have a lot more power..it's all seat of the pants stuff...
Old Mar 27, 2007 | 07:30 AM
  #333
rmartens24's Avatar
rmartens24
I wouldn't run level 3 on 87 for very long, your timing will be off and you will notice the difference. If you ever punch it down you will hear it. It sounds like a grinding/scratching noise.
Old Mar 27, 2007 | 02:00 PM
  #334
shawn001's Avatar
shawn001
Is my edge going to arrive tuned and ready or do I have to download something first ?
Old Mar 27, 2007 | 09:14 PM
  #335
kanarman's Avatar
kanarman
I have 2 buddies at work one that has 5.4 2 wheel drive that talks
trash to a guy that has the 4.6 4x4 with the edge tunner .
who do you think would win?
Could the guy with the 4.6 change the tire size to a taller one in the tunner to lower the shift points making it kinda like a 4.10 keeping the stock tires on it .
Would it be safe if he put it in 4hi to 60 foot better?
Old Mar 28, 2007 | 07:29 AM
  #336
rmartens24's Avatar
rmartens24
Shawn001,
Your edge will be ready to go. All you have to do is plug it in and choose your programming level. If you choose level 1, 2, or 3 and want to change some of the settings such as tire size you will have to customize the level. Otherwise, you will choose the level without customization.
Old Mar 28, 2007 | 08:30 AM
  #337
forcefed86's Avatar
forcefed86
I got mine installed and love it so far, although it has only been two days. It made a huge improvement in drive ability and the gauges are very handy. I am running level two adjusted for Tire size and gear ratio.
The speedometer is reading about three MPH faster that the edge display, any way to adjust that?
Old Mar 28, 2007 | 10:20 AM
  #338
onyx_rock's Avatar
onyx_rock
That seems to be the norm around here from what I've read. Min is about 2-3 mph different too.
Old Mar 28, 2007 | 08:30 PM
  #339
BIGFISH70's Avatar
BIGFISH70
Need some help I just installed my new Edge tonight and I keep getting a PCM code P0605 any one know what this?
Old Mar 29, 2007 | 06:37 AM
  #340
seredyns's Avatar
seredyns
I installed my edge last night and it made a large improvement in response. I have it on level 2 with the tire size corrected. I did notice one thing, however, when I went to set the tire size the number that was displayed did not correlate with the size of the stock tires. As a matter of fact it was way off. I thought the edge would display what it read from the PCM, correct? This truck is an 04 Scab was reflashed by the dealer about a year ago.
Also, Kudos to Discount Power Parts for quick delivery. I am very happy so far. Thanks!
Old Mar 29, 2007 | 07:35 AM
  #341
osteodoc08's Avatar
osteodoc08
Got my Edge last night. Thanks to DPP for fast and easy service and delivery. I had it in 3 days.
Anyhoo, I installed it last night and the gauges are worth the price alone. It is nice to be able to keep an eye on tranny temps, etc.
Old Mar 29, 2007 | 04:48 PM
  #342
CHIEF40AL's Avatar
CHIEF40AL
Edge update
I just talked with an Edge rep and he assured me the P0600 and P0605 code correction will be availble no later than next Wed.4/4/07
They have found the solution and are in the programing stage.
I added my name to a callback list that he had and they will call me(HAHA) when it is ready for download.
Old Mar 29, 2007 | 05:26 PM
  #343
TRX250R87's Avatar
TRX250R87
There are numerous tire/rim choices from the factor, so I think the Edge just uses a dafault size. What I don't like is that there is no way to see what size is selected after you made a change, it always goes back to the default number.
ERIC
Old Mar 29, 2007 | 07:48 PM
  #344
BIGFISH70's Avatar
BIGFISH70
My tire size was also wrong also the gears were wong also I have 3.55 and it stated that I had 3.73. Also my oil psi does not work. What is a good trany temp, what is too high?
Old Apr 2, 2007 | 08:20 PM
  #345
flip237's Avatar
flip237
2000 4x4 5.4 edge tune ,mac intake ,flowmaster exhuast.
not sure whats going on but when ever i give a quick tap on thorttle i get a knock or something but it only happen when the tuner is on program 2 or 3 it also happen with 87 89 91 gas if it on stock it dosent do it nor on pragram 1 id really like to know what this could be some told me it could be back pressure lifting my valves do to not having exhaust headers
__________________
