miles on your 4.9
Old Mar 19, 2013 | 05:05 PM
  #751
rikard's Avatar
rikard
Originally Posted by fast_st
Mine is running at 515k, still pulls strong and just finished plowing snow, pushes around a Fisher 9' hd plow pretty easy, sometimes it does want for a little more horsepower but generally its perfectly happy! Engine bottom end is all original, pulled the engine to fix a bunch of leaking gaskets and check it out, compression was good all across, bearings were within std spec as was the crank and journals. New cam cover gasket, front/rear mains, oil pan gasket and such. Head had new chrome exhaust seats installed at 260k miles and it still runs so delightfully well. This summer I will have to change the frame, 20 years of plowing has dissolved all the metal and have had a couple minor frame breaks that I've patched and sectioned. I have another frame sourced.
Rust is the big problem with vehicles here in New England. With 246k on mine its the rust that will eventually cause my trucks retirement.
Old Mar 19, 2013 | 06:46 PM
  #752
SideWinder4.9l's Avatar
SideWinder4.9l
203,700 on the clock now....still running as smooth as silk
Old Mar 19, 2013 | 08:52 PM
  #753
fastback69's Avatar
fastback69
218,977 miles. I made 3 pulls on a dynojet chassis dyno this past Sunday and the engine still manages 129hp/242lbft through an E4OD. The torque started at 225 and didn't drop below 200 again until 3300rpm or so. I have a home-made CAI, and 2-into-1 exhaust. I also added a MSD6 but that shouldn't really count for much. The trans was rebuilt around 155K miles and I put in a recalibrated accumulator VB. Not bad considering that I've never babied it. I even autocrossed it for two seasons when I couldn't work the clutch in my Mustang due to knee surgery.
Old Mar 19, 2013 | 10:15 PM
  #754
Duche400's Avatar
Duche400
Had a '76 f150 custom. 300 3speed, radio delete. 285,000 when I sold it. All the power I wanted with the 3.50L rear end. One tough truck!
Old Mar 20, 2013 | 08:10 AM
  #755
blue924.9's Avatar
blue924.9
company vehicle had 628 some thousand on it when we retired it due to a weak coil. got tired of 2wd and bought a 94 with 4wd and a 5.0
Old May 13, 2013 | 07:19 AM
  #756
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Mine has 843,000 on it now pulling a 3 car wedge trailer full time
Old May 13, 2013 | 11:57 AM
  #757
oneowner83's Avatar
oneowner83
As my name implies, bought mine new and at 180,000.
First ten years....much highway miles. Last twenty years....light ranch duty...I consider it my tractor.
Old May 13, 2013 | 02:35 PM
  #758
chrlsful's Avatar
chrlsful
mo bedda miahs
Originally Posted by oneowner83
"...I consider it my tractor."
Gasser that's a diesel!
(same w/mine)
Old May 16, 2013 | 12:52 AM
  #759
GMCPic's Avatar
GMCPic
2003 Ranger 3.0l V6 131,000 + starts, runs and drives the same as the day I bought it seven years ago.
Can't say anything yet about the 1980 F-100 4X4 4.9l. it has 70,964 mile on it.
Old May 16, 2013 | 05:24 AM
  #760
Duche400's Avatar
Duche400
A good buddy of mine bought a '77 extended cab long box. We used to go pick up cars on a tandem axle trailer with it. 300 4 speed. All you had to do was bump the key and she sang. It never had a problem pulling in the hills of Iron County, MI. Last I knew, there was 414,000 on the old boy. And that was a few years ago. What an engine! I wish my '67 had the 300 or even 240, but I've got the FE. Nice torque!
Old May 18, 2013 | 06:43 AM
  #761
Mailliws's Avatar
Mailliws
Just bought a 96 F-150, $800. 310+K. Still really strong. A little tlc will shine'm up. Wife named him Milo. lol. Looking to do some overhauling but not sure where to start. I would like to see better performance out of him. The engine is completely stock.
Old May 18, 2013 | 01:18 PM
  #762
evilci's Avatar
evilci
Got my '79 last year and it is running strong at 137k. Well it is running strong now that I fixed all the vacuum leaks, oil leak, and fuel leaks.
Of course I did do a bit of work on it new fuel pump, intake and exhaust manifolds, carb and every piece of rubber in the engine compartment .
Old May 19, 2013 | 06:55 AM
  #763
barnym17's Avatar
barnym17
I had a 79 with over 300,000 sold the engine 10 years ago after the roof rusted thru still running in a buddy's truck.My "New" Truck is a 92 with 215,000 on the clock 3.08 gear pulls a drag car 100 miles evry weekend avg. 15 mpg I plan on running it at least 10 more years.
Old May 19, 2013 | 06:40 PM
  #764
Black Ford XLT's Avatar
Black Ford XLT
As of December 2013, I got 532000 out of my 300, f150(1985).timing gear failed,so went ahead with a rebuild.On this post in 2004 I had 400,000 plus . After the engine was rebuilt, installed I did away with the carter carb (one barrel),installed the duraspark 2 system(ignition), Clifford intake , weber carb ,Clifford long tube headers, dual mufflers, magnaflow 3chamber,Rancho shocks .Wow what a difference this set up has made TR
Old May 20, 2013 | 08:27 PM
  #765
chrlsful's Avatar
chrlsful
back in the running
Originally Posted by Black Ford XLT
...After the engine was rebuilt, ...installed I did away with the carter carb (one barrel),installed ...the weber carb ,....Wow what a difference this set up has made TR
Which model Weber?
Thanks -
