I see where it shows @ E, 1; 2: 3: etc, but it does NOT show the color for that wire.
below is the PWR image, using the same 1,2,3,4,5 etc numbers.
clear as mud...
The e plug is pre amp outputs for rcas if your using external amps. If your just hooking the door speaker straight to the unit then you wire to the ones under PWR. The green purple grey and whites.
thank you,
I have worked in Electronics all my life, since 1958 and I abhor useless drivel for Documentation.
in my work, it was SPELLED OUT completely as to what goes where.
I have never bought a Radio replacement, not ever, this is the first one, and I got it specifically because it has the rotatable Android panel on it.
will get with the Program now, thanks
oh, really super Pissed Off because it does NOT have the proper Plugin Interface for a Ford truck.....
I bought a new plug kit to connect it up
The adapter harnesses are always sold separate cause there are some many model of vehicles. The radios are universal. Be impossible to include a harness for every vehicle with it. That's common so no need to be upset. If you have any other questions on the install just post up and I'll hell out best I cs.
Noice. I notice targetting markers in the second picture. Is handoff to the AGM-114 seamless?
That is so '80's. Pre-BackToTheFuture days. These hologram cars aren't DeLoreans.
Heavy ordinance is impractical when there are so many threat actors on the roads today.
They take up passenger and luggage space, add unnecessary weight, and slow you down.
And what happens when you run out? Return to base and reload? You wouldn't get very far, with the way the entitled Millennials and younger drive today.
Besides, destroying a vehicle ahead of you only slows you down, as you have to navigate around the carnage.
So no hand off needed. The vehicles that you see targeted are subjects of a far more advanced remote decryption / simulation / command / control system.
Basically a mobile version of what Big Brother can already do. Take command of the PCM of the target vehicle, slow it down, direct it off the highway, and shut it down on the side of a lonely road.
A new feature that was recently added is the ability to file an online classified ad under the "FREE ITEMS" section in the local Craigslist, to clear the car off road with plausible deniability.
More features to be added soon. Perhaps you would like to suggest some?
The adapter harnesses are always sold separate cause there are some many model of vehicles. The radios are universal. Be impossible to include a harness for every vehicle with it. That's common.
Usually the aftermarket radio's wires all have the same color for what does what. At least for the past 25 years. Maybe some foreign POS unit won't, but generally speaking that's true
we have a Blast Furnace in Full EFFECT here, looks like my outside Activities are going to get set on the Back Burner for a while - - - went outside at 2 a.m. and thought I would work while it is cool??
MOAR SCREEN!!
Philosin 13.3 Inch Universal Double DIN Rotatable Android Car Stereo with 4GB+64GB IPS 1920×1080 Head Unit GPS Navigation Car Radio Compatible with Apple CarPlay/Android Auto Bluetooth 5.0 4G LTE https://a.co/d/ckFtwTr
MOAR SCREEN!!
