ATOTO Android Head Unit Project...
Old May 18, 2024 | 10:58 PM
  #871
Hyakkimaru's Avatar
Hyakkimaru
Originally Posted by Tpayne621
It was around $500 for everything shipped to me. It's the teyes Cc3 and the 2k screen upgrade option. You can add 360* camera options. Tpms. All kinds of stuff to them.
https://www.teyes.com.au/pages/teyes-cc3-brochure
A little pricey but not as bad as I thought it was going to be for what it is. That thing looks sweet!
Old May 18, 2024 | 11:02 PM
  #872
Hyakkimaru's Avatar
Hyakkimaru
And it took me most of the day to get that radio set up and put in because of my foot. Getting out of my truck in my brother's yard I slipped off of a root in his partially washed out driveway and landed sideways on my foot. I am now probably going to be out of work for at least a couple days.... Considering I'm hobbling around with a baseball for an ankle, I felt like at least I did something today. I definitely wasn't standing at the tailgate of my truck to mount the radio to the dash. I came inside and did it on the kitchen table on a nice adjustable bar chair.
Old May 19, 2024 | 12:00 AM
  #873
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Roots have been bitter for you this past year.
Keep looking up. Branch out a little. You have strong trunk.
Old May 19, 2024 | 12:04 AM
  #874
Hyakkimaru's Avatar
Hyakkimaru
I see what you did there
Old Oct 20, 2024 | 11:47 AM
  #875
kbeefy's Avatar
kbeefy
Has anyone been able to set up the rear view camera to record?
I'm installing an S8 ultra into my campervan and it would be nice to record on an upcoming roadtrip in case someone rear ends me.
Also, I didn't know there was a OBDII to USB interface out there. Anyone have a link to a good one?
Edit... just looked on Amazon, theres a million of them. I'll figure it out.
EDIT EDIT: Sheesh.... I actually have an OBDII to USB adapter for my laptop and forscan. For some reason I thought it was serial, not USB.
Old Jan 31, 2025 | 06:11 PM
  #876
excursion_7.3's Avatar
excursion_7.3
TLDR....Could someone suggest what Atoto unit I might want to buy for my Volkswagen MK4 TDIs that I drive daily. I have the S8 Premium in my Exc but that is for what I consider to be my flagship vehicle that I was willing to spend more money on.
Thanks.
Old Jan 31, 2025 | 09:06 PM
  #877
josht's Avatar
josht
If you like the S8 you may want to compare the current offerings in that line.
I don't know when you bought your "S8 Premium" but new models of the line with new features are continually being introduced. Their current cheaper variations may have as many features as the older "Premium" did. Or might be a good time to upgrade the Exc to the latest and greatest, and swap the current to the VW.
I will say that I bought about the same version of the A6 as @Sous did back then. Mine had different button layout, but otherwise same specs. Their current A6 offerings appear to blow that unit out of the water. I'm seriously considering upgrading it to one the newer versions once I've got some other things take care of.
Old Jan 31, 2025 | 09:34 PM
  #878
excursion_7.3
Thanks for that. I see what you mean. I ended up getting the A6 PF refurbished for 100 bucks each on ebay. One for each TDI. Going to leave the one in the Exc alone for now.
Old Jan 31, 2025 | 09:59 PM
  #879
queen of spades's Avatar
queen of spades
Can anyone confirm if the newer models display Japanese kana correctly (as opposed to showing up as ???????)
Old Feb 1, 2025 | 09:13 AM
  #880
FordTruckNoob's Avatar
FordTruckNoob
Oh man I want this so bad now. Especially since this had happened to my radio.
Ma! My faceplate fell off!!
Old Feb 1, 2025 | 11:34 AM
  #881
Tpayne621's Avatar
Tpayne621
Spend the money and get a decent one like the teyes. I still have 0 complaints about it. Night and day difference compared to the cheap Amazon ones. There are a bunch of reviews on the teyes units on YouTube.
Old Feb 1, 2025 | 02:34 PM
  #882
ScaldedDog's Avatar
ScaldedDog
For those of you with an S8, have you had connectivity issues with yours, specifically between an OBD adapter and/or a dash cam? What I've found is that the late '23 firmware (231016 - 231120) seemed to cause that. Mine worked OK - though the dashcam connection was always wonky - before I upgraded to the late '23 FW last summer, and it never worked right after that. A couple of weeks ago I upgraded to the mid-'24 version (240527 - 240613), and both dashcam and OBD connections have been rock solid since. I hope that continues.
Mark
Old Feb 1, 2025 | 02:36 PM
  #883
excursion_7.3
Originally Posted by ScaldedDog
For those of you with an S8, have you had connectivity issues with yours, specifically between an OBD adapter and/or a dash cam? What I've found is that the late '23 firmware (231016 - 231120) seemed to cause that. Mine worked OK - though the dashcam connection was always wonky - before I upgraded to the late '23 FW last summer, and never worked right after that. A couple of weeks ago I upgraded to the mid-'24 version (240527 - 240613), and both dashcam and OBD connections have been rock solid since. I hope that continues.
Mark
Thanks for that. I never had an issue but this is great intel. I bought a Wi-fi OBD adapter that was identical to my working BT adapter and have never gotten that to run though.
Old Feb 2, 2025 | 09:30 AM
  #884
FordTruckNoob
Agree 100%. I am taking a serious look at the Teyes now.
Old Feb 2, 2025 | 09:45 AM
  #885
Tpayne621's Avatar
Tpayne621
If you got any questions just ask. I've had mine about 2 years now. I have the teyes cc3 with 2k screen option and the higher ram option. You can get almost any app you can get for a tablet on it. It's got Netflix and all. I have the favtory tailgate camera hooked to it and a dvr front facing camera that records. I didn't get theit front dvr camera I got a cheap one off aliexpress that looks exactly the same and works just fine also.
