Budget LED headlights
Old Aug 4, 2020 | 06:42 PM
  #811
BillyE's Avatar
BillyE
With some bulbs, you can adjust the depth the bulbs stick into the housing. This can make a big difference. Many stick too far in and that shifts the pattern up and changes the pattern itself.
Old Aug 14, 2020 | 10:14 PM
  #812
barry1me's Avatar
barry1me
anyone able to confirm which LED edge should be on top and which on bottom when they are faced in the 9/3 oclock position for the Beamtech 10k lumen ones?
Old Aug 14, 2020 | 10:54 PM
  #813
minke's Avatar
minke
LEDs, not headlights:
I bought some LEDs from superbrightleds.com with some mixed results. First I bought four 3157-R27-T-CK for rear stop/flasher service with some success. They were not 2 to 3 times brighter than the original incandescents as claimed. Anecdotally I’d say that they were a little brighter except from exactly behind from about 15 feet away. I viewed them as satisfactory and kept them.
For backup lights I got the 7443-NW27-T-CK that the website suggested. They didn’t even fit what we for historical reasons call a socket. That slot is not a socket! I returned them.
I made the order with the lowest cost shipping. For the six bulbs that was ~$2.50. As time went on they set and reset my expectations for delivery time multiple times. That was really aggravating. The bulbs did finally arrive.
superbrightleds.com performed adequately crediting my returned bulbs.
My desire for brighter flashers came about due to weather phenomena that I'd never experienced before. I am older than dirt and generally able to stay off the roads under bad conditions. Twice this winter fronts came thru with complete whiteouts lasting ~30 minutes when the weatherpeeps said that they had only 5 minutes notice. This was in the front range of CO. No, I didn’t get caught but I might have been caught.
I usually back up my driveway which is >300 ft. In the snow the standard backup lights are not particularly effective. I’m reminded of the time when I was little, around the time of the Peloponnesian War, when I had to wear a textured shirt said to be white-on-white. That is my driveway!
superbrightleds.com was OK.
Old Aug 15, 2020 | 05:08 AM
  #814
ZAR2USA's Avatar
ZAR2USA
....I'm reminded of the time when I was little, around the time of the Peloponnesian War, when I......
You are older than .....
Old Aug 15, 2020 | 08:14 AM
  #815
h20camper's Avatar
h20camper
Should be like this:
Old Aug 15, 2020 | 11:38 AM
  #816
Thevol's Avatar
Thevol
Anyone put these bulbs in a 2020 with a 7.3? Looks like the drivers side can be done without removing anything and the passenger just needs airbox lifted up, maybe they improved the design? Looks like a 5min job to swap the bulbs, but never that easy... Also are the Beamtechs still the best bang for your buck? I see you will need qty 4 H13 and 2 H10 for the fogs, is that correct still for the 2020?
Old Aug 15, 2020 | 12:33 PM
  #817
Lin19687's Avatar
Lin19687
Veteran: Navy
Pease read back the last 2 pages or so, there are posts about this.
Old Aug 15, 2020 | 12:48 PM
  #818
Thevol's Avatar
Thevol
Didnt read all 800 posts in this thread but looked back several pages and didnt see anyone who did them with a 7.3 engine bay. Just hoping it was as simple as it looked.
Old Aug 16, 2020 | 05:07 PM
  #819
ckal704's Avatar
ckal704
Installed BeamTechs in my 2020 6.7 350 and love them. Did headlights and fogs. Night and day difference in visibility!
Old Aug 17, 2020 | 09:43 AM
  #820
rivy2112's Avatar
rivy2112
What was your solution for your reverse lights? Did you just put the stock incandescent bulbs?
I've tried both the 7443s and the 3157s (both 'supposed' to fit in the '17-'19 models) with no success. They don't fit as you mentioned.
Old Aug 17, 2020 | 09:47 AM
  #821
minke's Avatar
minke
Back to stock.
Old Aug 17, 2020 | 11:02 AM
  #822
Jimmy Pet's Avatar
Jimmy Pet
I put these in my '19, they fit perfectly and are pretty bright. Not the life altering difference of the Beamtech LED from stock, but definitely worth doing.
I may have missed what year you are trying to fit though.
JDM ASTAR Extremely Bright 144-EX Chipsets 7440 7441 7443 7444 992 White LED Bulbs
Amazon Amazon
Old Aug 17, 2020 | 12:48 PM
  #823
rivy2112's Avatar
rivy2112
https://www.amazon.com/JDM-ASTAR-Ext...ct_top?ie=UTF8
I had LEDs like that both models I mentioned before, but they would wiggle/vibrate out of the "socket" in the image below (this is generic image). You haven't had that experience?
Old Aug 17, 2020 | 01:21 PM
  #824
Jimmy Pet's Avatar
Jimmy Pet
I had LEDs like that both models I mentioned before, but they would wiggle/vibrate out of the "socket" in the image below. You haven't had that experience
Not "yet".
They have no popped out yet, they have been in there since March.
So far so good with them.
What kind of timeline were you seeing of them wiggling out?
I have to admit of not putting alot of miles on the truck since install because of Covid which has stifled the activities I use the truck most for.
Old Aug 17, 2020 | 02:01 PM
  #825
mitzer61's Avatar
mitzer61
4wd Low
You are correct for 7.3. No need to remove grill, etc.
Driver's side is a little tight for the lower bulb but doable without removing anything.
Passenger side - pop out air filter box and very easy install.
Those four and two fogs took me about 30 minutes total using small step ladder.
