Lowering rear end
Old Jan 5, 2020 | 06:58 PM
  #511
Brian Exline's Avatar
Brian Exline
Originally Posted by camping nut
Blocks do not change the pinion angle as much as shackles. If it is a 350 the overloads will be closer to the pads with shackles. Bump stop will be closer with the shackles.
Good info. That’s what I was looking for. Thanks
Old Jan 12, 2020 | 10:25 PM
  #512
FIIFITTY's Avatar
FIIFITTY
Anyone have a 60 gallon titan or S&B tank with the rear end lowered? Wanting to do the PMF 1.5 or 2 inch rear blocks and adding a 60 gallon S&B tank in the near future.
Old Jan 13, 2020 | 01:37 AM
  #513
Bootlegfab's Avatar
Bootlegfab
I’m running the PMF drop shackles in the 1” drop setting and have no complaints FWIW.
Old Jan 13, 2020 | 08:26 AM
  #514
Jointasset's Avatar
Jointasset
A lot of info in here- anybody lower a CCLB? Did you go with the tapered blocks? I’m going to do 2” blocks and see how it looks w 295’s. I want 37’s but clearance issues are in play.
Old Jan 21, 2020 | 01:37 PM
  #515
BrianRich's Avatar
BrianRich
Wow this is a long thread, well i have the same dilemma needing to lower the rear of my 2020 F450 4x4 Crew Cab DRW. So I saw one thread by VooDooRob that said the part numbers for the shorter blocks and U-Bolts were for a F450 but I wanted to know if they would work on the new 2020. I just hooked up to my 5th wheel trailer and do not have enough room between the tailgate and the underside of my 5th wheel travel trailer.
Old Jan 21, 2020 | 01:45 PM
  #516
BrianRich's Avatar
BrianRich
Well I just went out to measure the block on my rear axle and their is only a 1" block so I really don't know what I can do to lower the rear of my truck. There is a 2" factory rake on my truck.
Old Jan 25, 2020 | 05:10 PM
  #517
NCMike's Avatar
NCMike
I had a chance to crawl under an 2020 f250 and 350 today. Both appear to have the same 2” block. I can’t be certain since I didn’t have my reading glasses on, but it looked like the back side was just a touch over 2 in, and the front a touch under. My guess is the new 2020 block has a built in taper just like our 2017-2019 blocks just at a lower height. No telling when they’d be available or at what cost, but it looks like a viable alternative to purchasing the aftermarket or older truck (no taper) blocks. Other than the block height, I didn’t see any difference in the suspension to the 2019’s sitting near by.
Old Jan 25, 2020 | 05:23 PM
  #518
dieseldrive's Avatar
dieseldrive
[QUOTE=camping nut;19039594]Blocks do not change the pinion angle as much as shackles.
They do if you go from flat to tapered, or tapered to flat
Old Jan 25, 2020 | 05:26 PM
  #519
dieseldrive
according to a local dealer the 2020 blocks are about $90 each (way more than the earlier blocks). Fords online parts catalog isn’t up for the 2020s yet. But at anywhere close to $90, the PMF blocks are a better deal, and better block, especially if you plan on adding air bags.
Old Jan 25, 2020 | 05:27 PM
  #520
Sixgear's Avatar
Sixgear
I removed the rear blocks from my '01 F250 4x4, yesterday. The blocks are tapered from 2" to 1 3/4" for reference.
Old Feb 8, 2020 | 08:52 AM
  #521
Brian Exline
Read through the thread and might have missed it.
I have 3.25" blocks right now and am ordering 2" blocks. Can anyone tell me what Ford U-bolt's I should order? I haven't found anything that shows lengths of the OEM U-bolts.
Thanks
Old Feb 8, 2020 | 09:14 AM
  #522
cficare's Avatar
cficare
There were several mentions of U-bolt lengths and their part numbers above (the search function should help you find 'em), but you really don't need new U-bolts. The U-bolts are torque-to-yield, and you will be using "fresh" threads further up the U-bolt. Apparently, it is the U-bolt threads which are torque-to-yield because I've seen no mention of having to replace the nuts each time. Of the two parts, the nuts may be a harder steel than the U-bolts. If you reuse the U-bolts, you'll want to trim off the excess afterwards.
Old Feb 8, 2020 | 09:47 AM
  #523
Brian Exline
Thanks, makes sense on the threads. Didn't think of it that way.
I did search but wasn't clear which ubolts go with the 2" blocks. Maybe I'm just slower than usual today.
Old Feb 8, 2020 | 10:24 AM
  #524
Sixgear's Avatar
Sixgear
I just removed the 2 " blocks from my 01 F250 4x4. the ride and braking greatly increased. I had to installed new u-bolts since the existing ones had the bolts at the end of the thread area. I used u-bolts from Husky, rockauto has lowest price for them. Husky Spring - Home
Old Feb 8, 2020 | 11:10 AM
  #525
Brian Exline
Thanks, I’ll look into them.
