Big Blue
Old Jan 23, 2017 | 01:57 PM
  #241
Gary Lewis's Avatar
Gary Lewis
Originally Posted by brad1979
Might want to look into why the outermost belt is twisted too.
Well, you caught me. I know exactly why that belt is twisted. That's because it didn't like sharing the pulley with my DVM's leads. Some dummy left them dangling a bit too close to the fan blades, and then hit the starter. It took several minutes to unwind said leads from the fan, but nothing was damaged - except my pride.
Old Jan 23, 2017 | 05:05 PM
  #242
Telestar's Avatar
Telestar
Nice looking truck! To me, people who are taking time to restore something like this see value where others don't. The ability to see that value & do something (if able) is a big deal to me. In a throw-away society where it seems like most people would just rather buy something new (not anything wrong in itself) than fix what they have is one of our society's failures.
Good luck with your projects & thank you for all the good information that you generously give to the rest of us.
Old Jan 23, 2017 | 05:15 PM
  #243
maytag906's Avatar
maytag906
Originally Posted by 85lebaront2
Heat is what kills these, the torque converter can actually get the fluid hot enough to boil and puke it out the vent which is inside the converter housing so it looks like the front seal is blown.
That's what killed mine. There is a small auxiliary cooler from the factory mounted in front of the radiator. Mine started leaking, so I bypassed it, thinking the main cooler in the radiator was enough. WRONG!
Now I know better.....
Old Jan 23, 2017 | 05:18 PM
  #244
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Gary, on the alternator, look at the wiring remembering my opinion of the crack heads at Ford who designed that system. Fusible links can and will fail from age. Oil leaks, timing cover gasket or front seal, looks sort of normal for a 460.
Old Jan 23, 2017 | 07:03 PM
  #245
Gary Lewis's Avatar
Gary Lewis
Telestar - Thanks! This truck is solid, stout, and has more documentation with it than any truck I've seen. It deserves to be "restored", although I'm not going to do it as a frame-off.
Maytag - I'll be sure and put a huge cooler on Dad's truck. And, keep the clutches from slipping.
Bill - This alternator is wired directly to the battery. No fuses involved, although I think that needs to be changed. But, are you telling me that I should expect a 460 to puke all over everything?
Old Jan 23, 2017 | 07:50 PM
  #246
Cienega32's Avatar
Cienega32
Originally Posted by Gary Lewis
My son told me yesterday that a couple of punks broke into a car in his neighborhood in STL and got it running but couldn't figure out how to drive the manual tranny so left it. Apparently it isn't just a joke.
There was a story in the last year [can't remember where] of a carjack gone wrong for the same reason - couldn't figure out a stick!
Gary, what ever happened to Rusty? I notice it missing from your sig.
Old Jan 23, 2017 | 10:30 PM
  #247
Gary Lewis's Avatar
Gary Lewis
Rusty will be sold to make room for Big Blue. My bride/confidant/financial manager says three trucks are enough: A fancy one like Blue, a sporty one with memories like Dad's, and a work truck like Big Blue. But I think the '50 Chevy got forgotten in the accounting.
Old Jan 24, 2017 | 02:55 AM
  #248
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
OK, I get that the module is properly connected, but are you sure that TDC on the damper is TDC #1?
It's not making sense to me that a $$$ gear reduction starter should be kicking back or struggling to turn a mild engine over.
Old Jan 24, 2017 | 06:33 AM
  #249
bruno2's Avatar
bruno2
Have I missed the post where you put the DVM on the positive stud of the alt to see if it was doing its thing?
I know you tried feeding the 460 a sacrificial DVM in hopes that would please it and in return expecting the charging issue to go away.
Old Jan 24, 2017 | 06:40 AM
  #250
85lebaront2
Jim, I agree with checking, between the oil leaks and age, I would question the balancer's accuracy.
Gary, if you pull the timing cover, go ahead and replace the chain set with the EFI set, it is a roller and straight up. If the "hatchet" (external counterweight) is grooved where the seal rides, I have an extra one. If the A/C has not been converted to R134, it does so quite well, I had done Darth not long after R134 became readily available and was pretty cheap. I used a red orifice tube, but Darth is a crew cab and heat + humidity around SE VA can be murderous in August.
Old Jan 24, 2017 | 07:05 AM
  #251
Gary Lewis's Avatar
Gary Lewis
Jim - I haven't, yet, checked TDC. And that is suspect since I installed the pointer when I got the truck. But, I checked the crank signal to the DS module because it was easy and I already had the sacrificial DVM there to check battery voltage.
Brandon - I didn't put the DVM on the post of the alternator. But I did pull the wire that goes from the alternator to the battery and confirmed that it is solid. And when I reinstalled it I confirmed that there was battery voltage on the wire. So, essentially I did put the meter there, and the only thing the alternator does is go round and round.
Bill - This is a new engine with less than 2000 mikes on it. The balancer is new, as is the timing set. I don't remember the brand of it, but probably have the receipts, although Vernon spec'd good stuff so I don't have any worries there. But, the front main seal can be replaced without pulling the timing cover - right?
On the A/C, it was converted and worked last summer if I understood Vernon correctly. But the compressor doesn't come in now, so it is probably down on pressure.
Old Jan 24, 2017 | 07:24 AM
  #252
bruno2's Avatar
bruno2
So about the alt issue...... Is it still under warranty? Are going to rebuild that one? Is it time for a 3G swap? What is the conclusion?
Old Jan 24, 2017 | 07:29 AM
  #253
Gary Lewis's Avatar
Gary Lewis
I'm going to see if it is under warranty and if the warranty applies to me. If not I'll probably have it rebuilt, or rebuild it myself if it is an easy fix. I'm wondering if the oil from the front main seal leak has coated the slip ring.
Old Jan 24, 2017 | 08:01 AM
  #254
85lebaront2
I believe so, I recall it has a flange that is outside the cover when installed. A couple of items, first, in order to get the "hatchet" off, the balancer key may need to be removed, second, if the timing cover was not properly aligned when installed, it will eat seals, there are no dowel pins on the front like the M blocks so proper alignment is the key to seal longevity.
Old Jan 24, 2017 | 09:44 PM
  #255
rowdyredneck's Avatar
rowdyredneck
Yes. You'll have to pull the balancer off first, then remove the key from the crankshaft and slide the counterweight off. As I remember the keyways for the balancer and weight aren't aligned so you have to remove the outer key first. Before you pull anything apart though I'd spray it all off with some brake cleaner and run it a little more to make absolutely sure that's where the leak is coming from.
