Build Time!
Old Apr 1, 2017 | 05:41 PM
  #181
dclack's Avatar
dclack
I'm starting to want a newer truck! I crawled under it today to check the dipstick adapter and fuel line for leaks. So far those are my only accomplishments.
Then I started to look around to see why the drivers side is still wet and found the following:
Looks like I need a VC gasket...
And a filter on the CCV (I got tired of the smell and fumes under the cab, so I put it back in the intake last week)...
And this too!!!!
Old Apr 1, 2017 | 06:43 PM
  #182
oldbird1965's Avatar
oldbird1965
Looks like that valve cover is tweaked. You might check it for being 'warped'. I know I had one leaking, new gasket and still leaked. I layed it on a flat surface and lightly tapped on it and no more leaks. I can't tell, where is that crack?
Old Apr 1, 2017 | 06:59 PM
  #183
dclack's Avatar
dclack
The crack is in the frame just in front of the front body mount. I'll have to check the vc before getting a new gasket.
Old Apr 3, 2017 | 09:35 AM
  #184
DIYMechanic's Avatar
DIYMechanic
I Just came across this thread and read all 13 pages to get caught up to speed. Keep up the good work. These old trucks are worth preserving, and they're well on their way to becoming classics.
Old Apr 3, 2017 | 10:46 PM
  #185
dclack's Avatar
dclack
Thanks Nate. I'm just getting frustrated with the usual one step forward, three steps back. To many projects and not enough time.
Old Apr 4, 2017 | 06:16 AM
  #186
DIYMechanic
That's the truth! My list is growing faster than I can mark things off of it. I try to remind myself to enjoy the tasks I like and just accept that the work can be its own reward sometimes. But yeah, I think we all get weary of it sometimes....
Old Apr 4, 2017 | 12:22 PM
  #187
BBslider001's Avatar
BBslider001
I felt this sentiment pretty deep the last couple of months. Hang in there Darin!
Old Apr 14, 2017 | 04:28 PM
  #188
dclack's Avatar
dclack
Three weeks since I re-sealed the compression fitting and still dry. I'm calling that a win! I need all I can get.
Sorry, not much of an update as I haven't had any time to address the VC leak yet.
Old Apr 17, 2017 | 06:21 AM
  #189
DIYMechanic
Are you sure the VC is actually leaking? You can run these engines with the VC's off completely and not lose any oil. Could it be one of the HPOP hose fittings or a gallery plug or something leaking? I don't know that I have ever seen an actual VC leak on these engines, but hey, I guess there is a first time for everything.
Old Apr 17, 2017 | 09:21 AM
  #190
dclack's Avatar
dclack
It sure looks like the VC to me. An HPOP hose leak would run down into the valley and a gallery plug down the back. This is running down the middle of the drivers side block. But you're right, I've read that you can run without the VC (never done it myself), but as I understood it, that was only at idle; anything beyond idle and oil goes everywhere.
Old Apr 19, 2017 | 05:57 AM
  #191
DIYMechanic
Yeah, I've run them with the VC's off before, but it was just at idle; that may be the case. At any rate, like I said, there's a first time for everything! Hopefully a VC gasket solves it for you.
Old Apr 19, 2017 | 10:23 AM
  #192
BBslider001
Yeah, anything above idle and oil starts to go places...LOL....I am hoping the VC fixes it as well.
Old Apr 19, 2017 | 10:48 AM
  #193
dclack's Avatar
dclack
I'm just going to need a free weekend to do it. And then there's the SD UVCH, should I upgrade that side now and do the other one later?
Old Apr 19, 2017 | 11:05 AM
  #194
dclack's Avatar
dclack
I probably just do the Dorman SD gasket. It's $70 for a Fel-Pro OBS gasket only; $66 for a Dorman OBS gasket, pigtail, and UVCH; and $73 for a Dorman SD gasket, pigtail, and UVCH.
Old Apr 19, 2017 | 03:53 PM
  #195
BBslider001
Or just get an SD ONLY kidding...
